Question about HTC Explorer A310e Android 2.3 Unlocked Quad Band PDA Phone Black
When During calling someone or recieving call phone screen is off. and cutt the call. screen is not onby pressing power button
    Problem Solver:
  • 12 Answers
The screen goes off when you cover the proximity sensor with your head. On this phone its in the top of the bezel. It should come on again when you take the phone away from your head, if not, make sure the top of the phone is clean,m in particular any speaker grills are clear of dust and you aren't covering the top with with your thumb.
Posted on Oct 15, 2013
When i press Green Call button, my call log comes on. but when i press it again to call someone, it cannot call out, even when i press select button. cannot recieve calls too.
you have to properly get out of that calling mode and than call again after properly logging off the call. This is a low end phone. Don't expect too much from this.
Jan 30, 2014 | Nokia C3 Cell Phone
How to mute during call from physical button?
Press volume up and down button that will mute ring
Jan 01, 2018 | Samsung Cell Phones
Dear Sir, My Screen Of Samsung S8300 becomes blank whenever I make or call or recieve any call. In this stage the there is no response from the screen, but I can hear and talk on the phone,( I am not...
  1. first problem screen blank out
your mobile has a sensor at the top of you phone which is use to make you screen blank when you keep your phone near your ear to save power during a call.(it may be a sensor malfunction)
2.the vertical lines occurrence is common in all mobiles there's no prb with that!!!!
Jun 14, 2011 | Samsung S8300 Ultra Touch platinium-red...
My touch screen will not work i can recieve calls but can't dial out or explore the phone in any kind of way nothing but the on/off button works what can i do?
My dear friend, what you have to do is to calibrate the screen. Be sure that the phone is not locked from the side of the phone before trying to calibrate the screen.
To calibrate the screen, please follow the steps below:
  1. Power off the phone,
  2. Press and hold the top left corner of the screen,
  3. Keep holding it as You also hold the dial/green button and the middle/menu button,
  4. Keep holding them at the same time as You ask someone to help you press and hold the power button for about 30 seconds,
  5. A page will come up with some touch dots on the screen,
  6. touch every dots and follow the rest of the instructions from there on, that way, the screen will be calibrated and will work once again.
If that does not do the job, then it means the sensor board is bad and need to be replaced. Hope this information helped you. Thank you for using fixya
Jan 16, 2011 | LG Vu CU920 Cellular Phone
Cannot recieve sms, cannot add or delete anything. cannot receive phone calls or make any
Start by formatting the phone, it is your best bet.
How to Format Nokia N70, N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
May 17, 2010 | Nokia N70 Cellular Phone
I'm having a problem with my screen turning black as soon as I make a call or recieve a call it comes back on when I plug it in. I can't hangup from a call or anything when it does go black can someone...
The screen on the droid shuts off to conserve battery power. The amount of time that it remains on can be adjusted in the settings menu, under sound and display, screen timeout. The screen can be turned back on after a timeout by pressing the power button on top of the phone momentarily (quickly, dont hold down). Also, the screen will go black when you hold the phone up to your ear, and then light back up when you remove it from your ear. Hope this solves your problem, if not just let me know.
Jan 18, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
The phone works, recieves and makes calls but both screens are dead???? verizon motorola razr v3
How about the buttons next to the screen? If you do not hear anything when you press those buttons, it is going to be the flex cable. The flex cable connects the phone between the hinge. It connects the 2 displays (it's really one display part with both screens, it has a screen on the front and back).
Basically you have the most common problem with the RAZR, the screen part connects to the bottom via the flex cable and is partially damaged or has ben severed. Not terribly hard to fix but you would need someone who can take it apart and who can get the part as well.
Oct 23, 2009 | Motorola Mobility RAZR V3
How do I transfer calls to someone else in the office using Norstar T7316 phone?
If your telephone doesn't have a transfer button programmed press feature *3, the button you want the transfer button to be, and enter feature 70. While on the call press the transfer button (or press feature 70) and the extension you want to transfer to.If you want a screened transfer, wait til the extension called answers,and ask if they wish to talk to the caller on the line. if they dont, pick up the caller off hold. if they want to talk to them hang up and they'll recieve the call. If you want to blind transfer, hang up after youpress transfer and dial the extension and they'll get the call without screening.
Sep 28, 2009 | NorStar T7316E Corded Phone
Voice call/mp3/general sound issues
I have the EXACT same problem...driving me nuts. Someone please HELP.
Nov 23, 2006 | Motorola Mobility RAZR V3
HTC Explorer A310e Android 2.3 Unlocked Quad Band PDA Phone Black Logo
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
