Question about Eureka Vacuums
Netflix error b1-n110 - Eureka Vacuums
I have an error reading e1 but the bobbin and thread are fine
You need to hold the thread tightly when you do your first 5 or 6 stitches. The pull out card on the machine will tell you exactly what the E1 error mean
Jan 02, 2015 | Singer Futura CE-250
Battery error messages
I agree with JE :).
Did you check the old batteries with a volt meter? With the same error message pre and post replacement, either you are one of the people with bad luck, or it's in the "brains". You can attempt fault isolation, but I don't know if it would be worth the time since replacement parts from manufactures are notoriously expensive.
Finally check the charging station. Clean the rails on the charger, and the connections on the machine with alcohol. Sometimes the worst problems can be solved with one simple action, or at least Occam said.
Aug 24, 2014 | Neato XV11 Vacuum
It's been years since I sewed anything and now I can't seem to get the bobbin to thread properly, I've tried several ways and none work. Help please
This is a picture of typical bobbin threading. The thread should go around the bobbin and come out through the slot in the same direction...see B1. The thread goes from inside the bobbin through the slot to the outside of the bobbin case. The screw adjusts the tension on the thread as it comes out.
If you mean how to thread it to wind the bobbin we'd need to know what model and brand of machine you have as they're a bit different in how that's done. In older machines it was often on top, sometimes towards the back of the machine towards the wheel. The thread went through several guides and it wound the bobbin only when you pushed the spool post that held the bobbin up against the wheel that caused it to turn, after releasing the hand wheel on the back so the needle wouldn't go up and down as it wound the bobbin.
May 03, 2011 | Singer Vacuums
The vacuum was on when my son tripped the cord and one prong broke off in the outlet. We patched on another cord. It won't turn on tried other outlets. Can't find reset switch, is there one or did we...
Maybe you got the wires crossed between the two cords. Vacuums have polarized plugs and if wired imcorrectly can definitely cause the vacuum to not work. Try switching over.
In other words, consider current wires as A1/A2 and B1/B2. Disconnect, then connect A1 to B2 and A2 to B1.
vacuum===============A1 A2=======Plug
===============B1 B2=======Plug
Switch to
vacuum===============A1 B2=======Plug
===============B1 A2=======Plug
Try this and see what happens.
Jan 03, 2011 | Dyson DC14 All floors Bagless Upright...
JUST GOES IN CIRCLE
It may just be fried, or has a problem with it's programming. talk to the factory, and see what you can do. If it's still under warrenty, send it back.
Aug 12, 2010 | iRobot Roomba 560 Robotic Vacuum
Vacuums Logo
32 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
