Question about Coffee Makers & Espresso Machines
I have a Bunn-O-Matic 3 Burner STPF-15 coffee maker. The problem is it overflows the pot, leaks and water starts going into the basket as soon as you turn the burner on (not the brew button). I hope someone can help me figure out what is wrong so I can get an estimate on having it repaired.
SOURCE: Black and Decker Coffee Maker DE790B
There is nothing wrong with your unit, This is not a problem. There is no burner at all. This is a thermal carafe unit that does not require a burner to keep the coffee hot, but rather it's the thermos like quality of the carafe that keeps the coffee hot.
Posted on Jan 03, 2009
  • 131 Answers
SOURCE: bunn pour omtic 3 burner
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Posted on Feb 12, 2009
  • 131 Answers
SOURCE: Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Posted on Feb 13, 2009
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Posted on Mar 08, 2009
SOURCE: MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Posted on Mar 16, 2009
My Commercial bunn CWTF-DV-3T coffee maker is leaking water from the top right corner of the machine,and now at the base, behind the burner on the bottom. This happens only when you start to make a pot of...
the fill drain is plugged and the water is overflowing. open the top and, using a phillips head screwdriver, poke through the lime buildup in the trough drain until the water goes down more freely.
Feb 17, 2014 | Bunn NHB Coffee Maker
COFFEE MACHINE KEEPS FIL;LING UP AND OVERFLOWS. tHIS IS A BUNNOMATIC MODEL STPF-15
Dunkin Donuts decaf coffee clogs the filter as the water fills the basket causing the basket to overflow. The coffee is ground too fine. Swtich brands or use a second filter to cover the coffee grounds to keep them from floating and clogging the filter.
Feb 24, 2011 | Bunn A10 Coffee Maker
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Bunn STPF-15, Pot overflows, Intermittently.
The sprayhead tube has scale buildup, use the deliming spring to clean tube and then clean sprayhead.
Oct 23, 2009 | Coffee Makers & Espresso Machines
Bunn coffee pot blows water out top of basket
Check the grind on the coffee, brew a pot without coffee and if it overflows, then the machine has a problem. If it doesn't then try a coarser grind on the coffee.
Jun 14, 2009 | Bunn Coffee Pots: Thermal Carafe
Coffee maker leaks
Please contact customer service and a seal kit can be sent to you that should fix your leak-it is successful about 90-95% of the time.
May 27, 2009 | Bunn-O-Matic Coffee Brewer GRW8
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Overflowing basket
The grind on your coffee is too fine, and if not there is too much coffee in the basket, hence the overflow.
Jan 02, 2009 | Wega Mininova EPU Espresso Machine
Coffee Makers & Espresso Machines Logo
64 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
