Question about Garden
Stihl re125k pressure washers
What type of oil is required for the pressure engine
jj505
  • 195 Answers
SOURCE: power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Posted on Apr 14, 2009
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 583 Answers
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 623 Answers
SOURCE: I have a troy built 2450 pressure washer. The
Do you live where it is cold in the winter? And did you winterize the pump this past winter if it is cold? They need to be winterized or pump damage can occur.
Posted on May 10, 2010
  • 21 Answers
SOURCE: Which type of oil do I use for my Honda G200 5.5hp
straight 30 weight oil
Posted on Aug 29, 2010
Testimonial: "Many thanks."
Re Stihl RE125K power washer. How to get a focused jet? Is the nozzle adjustable?
the best nozzle to use for your requirement is a turbo nozzle
It sprays a cone pattern that spins in an eccentric circle so that what ever is being cleaned is attacked from all angles
some machines do have adjustable nozzles so talk with your stihl dealer for ideas as to what is available
Aug 19, 2016 | Garden
How do I get the soap to work on a Stihl RE125K washer thanks
your wand has a variable nozzle...you can turn the nozzle on your wand to adjust the width of the spray pattern...You can also push it out or pull it in from hi to low pressure....You need to pull it to low pressure so that it draws chemical through your chem injector. Good luck
Feb 24, 2015 | Garden
The Remington 3.0 peak HP requires oil what type
I recommend Stihl Two Cycle oil for use in all two stroke engines (except motorcycles) especially in the cheap throw away box store saws. However in any 'professional' rated saw, you should use the respective oil for that manufacturer...Homelite uses its own oil, Husky uses it own oil, McCoullagh uses etc......
Oct 13, 2014 | Garden
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
What type of fuel do i need to use for my p/w? Does it require oil/gas mixture? Thx.
Your Honda would be a four stroke engine, so your fuel would be straight gas, you will notice on the base of the engine there is a location to put oil, a 4 stroke engine is lubricated by the oil in the base of the crankcase. On a two-stroke engine.oil fuel mixture lubricates the crank so it has no provision to add oil to the engine.
Feb 19, 2011 | Karcher 2500 PSI Pressure Washer
I am trying to find out what type of gas is required in the Stihl sh56c
Hello odellywelly. The sh56c is certified to operate on unleaded gasoline and the Stihl two stroke engine oil at a mix ratio of 50:1.
Use regular gas. If you get a 2.6 fluid ounce bottle of the Stihl 50:1 oil, add it to exactly one gallon of gas. DO NOT mix up more than you will use in a few days. As it sits it deteriorates and you will have difficulty starting the engine. Joe
Thanks for choosing Fixya!
PS Here is a free download of the owner manual for your use. http://www.stihlusa.com/stihl_ownersmanuals/BG_56_66_86_SH_56_86_Manual.pdf
Nov 30, 2010 | Garden
Does pressure washer pumps need oil or not?
There are certain pressure washer that do require oil. It depends on your make and model of he machine.Usually they require, when it is a gas powered unit and then if its a 2 cycle gas engine they take a gas/oil mix in the tank and do not require oil in a crankcase.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2009 | Briggs & Stratton Garden
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Fuel requirements for a Stihl 131 Polesaw with the 4mix engine?
hi Ray
For your polesaw Stihl HT 131 with 4 mix engine you need a fuel/ oil mixture.The lubrication of the engine is realised through the fuel/ oil mixture(you need a superior quality of the oi for the mixture ).Buy it from an authorised Stihl dealer shop.Any other oil is not needed on the 4 mix engine.
best regards savumihai71
Dec 05, 2008 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
