Question about Noritz Water Heaters
My noritz water is throwing a error code 94. - Noritz Water Heaters
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Posted on May 12, 2009
senor8
  • 73 Answers
SOURCE: what is error code 59 on a noritz tankless water
The 59 code is typically caused by insufficient gas supply to the unit. It can also be caused by obstructed exhaust flow, stuck exhaust damper (located directly on top of the unit's exhaust), insufficient makeup air, or improperly installed venting (i.e. too long or too many elbows).
I would recommend initially checking the incoming gas pressure at the gas connection on the unit. The gas pressure should not drop below 5" water column for a natural gas unit, 8" for a propane system (the unit need to be operating at its maximum output).
Posted on Aug 14, 2009
SOURCE: Noritz Tankless error code 16
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLR periodically. Code 11 is ignition error. Is your gas valve turned on?
Posted on Dec 09, 2009
senor8
  • 73 Answers
SOURCE: getting error code 16. what does it mean and what
a 16 error code is typically caused by scale formation. I'd recommend performing a descale on the heater.
Posted on Jul 12, 2010
senor8
  • 73 Answers
SOURCE: error code 14 shows on the remote for a noritz
This means the thermal fuse has broken and needs replacement. The thermal fuse is a white cord which wraps around the heat exchanger. It typically breaks if the unit is excessively dirty and sooted. Before the fuse is replaced you should make sure the unit is cleaned with compressed air and descaled.
Posted on Jul 15, 2010
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
What does an error code 66 mean on a noritz Model N-0751M
http://www.noritz.com/u/pages_from_field_manual_2010_12_09_pdf__adobe_acrobat_professional.pdf
The Noritz field manual says that error code 66 is Bypass Water Control Valve failure. Call support at 866-766-7489 with your model #, serial # (both on the unit face plate), date of purchase, to see if the valve can be replaced under warranty.
Jul 14, 2012 | Water Heaters
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
What is error code 043 on NORITZ tankless heater?
There is no error 43 on a NR71. There is a 73 error code which is caused by disconnecting jumper cables while the power is on.
Oct 29, 2010 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Getting error code 16. what does it mean and what
Mar 06, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Panel is flashing a 20 code and water is ice cold. Unable to reset system from control panel.
I was just told by Noritz America that flashing 20 is hard water issues. Any confirmation on just what this error code means?
Nov 01, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Oct 17, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Water Heaters Logo
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
