Question about Hardware & Accessories
Hy mag timer switch
How do i set my SAT hy mag time swit h?
2 Suggested Answers
  • 5245 Answers
SOURCE: how to set Hy-Mag pool timer switch
Be real.
Describe the timer in detail, and include the model number and take a photo and post on flickr.
Add a comment with missing information.
Is this a timer, or circuit breaker?
Posted on Oct 09, 2012
Pictures how to set crank pulley timing markings of a Honda Ballade 150 pop up lights 1988 automatic
Ek het n honda ballade 150 ek het vir hom n ander kaberytor op ge sit nou sukkel hy om te staart en as hy stard dan mis hy wat kan voud wees
Jun 18, 2013 | Cars & Trucks
How to set Hy-Mag pool timer switch
Be real.
Oct 09, 2012 | Hardware & Accessories
Microwave oven doesn't heat.
Yes! I have come across the odd case where the magnetron was intermittent, fortuneately it is rare because this type of problem is very difficult to nail down.
Jun 07, 2012 | Kenmore Microwave Ovens
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
Nov 08, 2010 | Coleman Cable Woods 59018 InWall 7Day...
6600 power switch jumper
how to have cellphone
Oct 25, 2010 | Nokia 6600
Dish Pro record code for Mag combo
ZNREL, I've done this with Dish Pro before. Setup the Dish remote to control the Mag combo in the VCR position. Press the SAT button and select the guide. Go to the program in the guide and select it. The "record this program" routine should pop up, set it up. Here's the key, make sure the Dish remote has the VCR button selected and that the remote is placed where it can "see" the Mag combo. At the set time, the Dish remote will change the DishPro to the proper channel and then issue s "record" command via infrared to the Mag combo to start recording. DishNet has all of the device codes to their remotes downloadable from their site.
Mar 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Hardware & Accessories Logo
121 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
