Question about RCA 20F610TD TruFlat TV/DVD
Horizontal lines/"snow" The screen is full of horizontal lines or "snow", it will flash back and forth with a good picture, but, is mostly "snowy". It is not viewable at all in this condition. I tried to go into the menu program under "tuner" to ty to fix it---nothing! Please help
  • 68 Answers
It sounds as iff it the arial connections ?? are the problem check the connections you may need new cable? use 75 ohms cable
Posted on Apr 23, 2009
  • sandra mac dougall Apr 23, 2009
    it sounds as iff it the arial connections ?? are the problem check the connections you may need new cable? use 75 ohms cable
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
There is a sound but no picture in to the screen and there is horizontal line
Tv have a Horizontal IC out is dead or cold soldering.Make a fist with ur hand,bang on the tv frame bazel a couples of times.If the hoizontal line flashes back to normal screen?Tv have cold soldering around horizotal IC area.U have a soldering iron tool and a roll of solders,know how to do basic soldering?Take the back of the plastic screw driver tap around for cold soldering area.Resoldering those area.No horizontal tv screen flashes back the IC out is dead,require replacing another horizontal IC output.
Mar 21, 2011 | Televison & Video
Loss of sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Jun 12, 2009 | GE 27GT271 TV
Intermitten snowy picture
well the vertical deflection IC is good but you need to get the conversion chip for it , it controls the vertical , horizontal, color, color alignment ,
it would be wise to get it done soon before anymore dammage is done
Oct 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Constant horizontal lines
Good Day, valscot;
The most common problem with model i some caps on the signal board, CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
good Luck big IRISH.
Aug 14, 2008 | Mitsubishi VS-50605 50" Rear Projection...
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Lines on screen
Can you take a picture of the screen and post it? It is not possible for both the horizontal and vertical stages to fail at the same time to produce a cross. A picture of the screen would help significantly.
Aug 08, 2007 | Daewoo DTQ-25S2FC 25" TV
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
RCA 20F610TD TruFlat TV/DVD Logo
131 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
