Question about Lenovo E20 TS I3-550 2GB/250 SG W7-64 (422294U) PC Desktop
PIONEER EQUALIZERS SG-550 Graphic Equalizer manual
A pioneer gr-333 graphic equalizer which is labelled on back side; all input and output is written on tape only..Can i connect a cd player on this terminal?
Yes, connect to TAPE PLAY.
Then you come out of EQUALIZER OUT to your sound system.
There are other ways to do this, but it all depends on the rest of your system.
DOWNLOAD THE MANUAL FROM THE NET.
Peace-
Jan 04, 2016 | Pioneer Audio Players & Recorders
How do you connect a home pioneer graphic equalizer sg-9 to a sansaui r-7 receiver?
Use the tape monitor loop. Connect from the TAPE REC output on the receiver to the INPUT on the equalizer and from the OUTPUT on the equalizer to the PLAYBACK input on the receiver. YOU can then switch the equalizer in and out using the TAPE MON switch. I think the Model Seven had two tape loops, so just keep everything on the same loop.
Aug 03, 2014 | Audio Players & Recorders
I have a pioneer VSX D-308 RECIEVER and a electro-voiceevt 2210can it be hooked up together
The Tapco equalizer was a very popular line of equipment which was eventually bought up by Electro-Voice. Could not find any online manuals, however found online images of back panel. It appears to have Tape Ins & Outs.
Unfortunately the equalizer you have is not compatible with the receiver unless you have special cables that have built in transformers. This unit has T&R connectors (tip & ring) meant for professional sound equipment.
On a typical home stereo receiver you would hook up your equalizer with RCA connectors as follows.
1) You take the output of the equalizer and plug it into the input of the receiver.
2) You take the output of the Receiver and plug it into the input of the equalizer.
Start with lower volume and your tape switch on the receiver to the on position. Play with the various controls on your equalizer to
Apr 17, 2014 | Electro-Voice Tapco Graphic Equalizer,...
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Graphic equalizer how to connect for my turntable to work with it
There should be the connections from the turntable connected to the input of the equalizer then the output of the equalizer to an amp
Some turntables require a preamp so refer to your turntable manual.
(Some equalizers act as a preamp) You wont hurt it by trying it.
Jan 04, 2013 | Mitsubishi Da-g108 Stereo Graphic...
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
Using graphic equalizer on a Pioneer CD player
try to connect it in tape in-and confirm that you select the right input in the receiver(in our situation you will select tape as input source).
Sep 14, 2009 | Audio Players & Recorders
I have a Pioneer SG-540 stereo Graphic Equalizer that only works in the right channel, but more importantly puts out a large amount of excess humming moise and other unwanted sounds when the controls are...
I use the sg 540 equalizer for cd and tuner. (I have two of them) I also use the sa 940 to power my sound. On the tuner input of the amp, i used standerd rca cables and connected it to the output of the equalizer. then i connected rca cables from the input of the equalizer to the output of the tuner. this only works when the top equalizer button is pushed on. hope it works for you.
Jul 18, 2008 | Audio Players & Recorders
Lenovo E20 TS I3-550 2GB/250 SG W7-64 (422294U) PC Desktop Logo
149 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
