Question about Panasonic KX-T7885 Cordless Phone
KX-T7885 need to program to work with a KX-TG2000B
I am trying to test a KX-T7885 by programming it to work with a KX-TG2000B. Can this be done? Thanks, Kelly
  • 201 Answers
No, it cannot. Not even close. You are stuck with the KX-TGA200b, KX-TGA400b, KX-TGA420b
Posted on Sep 25, 2007
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
I have 2 Panasonic wireless phones ModelKX-T7885 and a panasonic PBX. One wireless phone will not display F1 thruF4 lines; it displays F9 thru F 12 only depspite reprogramming the unit to default settings....
Hello, Peter.
Try resetting your modem / router that provides the connectivity.
Then, if necessary, re-power (Off and leave for 10 minutes, then On) your phones.
Hope this helps.
Sep 15, 2010 | Panasonic KX-T7885 Cordless Phone
Phones won't charge
have tested the charger if it is working?
if you test the charger with another phone and is working perfectly then the charging port of your phone is bad.
the charging port is the port where you insert the charger.
try and get a new charging port and replace with the bad one, the phone will charge.
thanks for using fixya.
Jun 06, 2010 | Panasonic KX-T7885 Cordless Phone
Can not get kx-t7885 to get a dial tone. The phone is paired with it's base, and will get the panasonic dial tone but not an outside line.
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Nov 22, 2009 | Panasonic KX-T7885 Cordless Phone
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
Finding replacement battery kx-a276
Take the battery out and take it to Walmart or Radio Shack. A lot of times you won't find that exact model number but the batteries they sell are exactly the same.
The Number kx-a276 is just the Panasonic model number for a battery many other phones use. On the back of the battery package replacement you should see "kx-a276" listed.
Hope this helps!
Fix it?
Jun 01, 2009 | Panasonic KX-T7885 Cordless Phone
KX-T7453 co light will not light when someone is on the phone
I don't know what instructions you have, but try these.
Press PROGRAM 99 and the button you want to program
Dial 1 plus the extension number and STORE.
Was that what you were doing?
Aug 21, 2008 | Panasonic KX-T7453 Corded Phone
As the voicemail system can be quite complex with mailbox password setting etc. I think you will need the manual to help you along at some stage, so here is the link, just click on "download"...cheers.
( it's free )
Jan 22, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-T7885 Cordless Phone Logo
363 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
