Question about Titan Air Tools & Compressors
I have a titan 400 i paint sprayer, won't prime.. any suggestions ? Thanks, can't get anything through it... motor is running and all. Shawn
  • shawn_fisher Apr 24, 2009
    Mine is the short low to the ground unit, where is the ballbearing located ? I screwed off the end but its just hose and the filter ...
    Thanks
    Shawn
  • Anonymous Mar 18, 2014
    paint sprayer wont prime, cleaned all ball things and even cleaned the ball that inside white cage plastic thing but notice its missing 2 bars
OK, Just solved this problem with my Titan 400 not priming....After searching the internet I got the clue that it was the inlet ball valve being stuck. Most said it was from leaving paint in the system or poor cleaning habits. I thought "Not me, I always do a good job cleaning the sprayer and leaving pump preserver in the system when storing". But I was wrong. After disassembling the inlet valve housing (shown in the manual) I found the valve ball stuck to the seat. After freeing the ball there was tiny bit of paint on the seat but it was enough to prevent it from functioning. Reassembled and it works fine. So maybe just luck of the draw. I don't use the system too often and it had been 6 months since the last use...still I stored it with line full of pump preservative. Symptoms were that when in prime it would not **** from the siphon tube (supply) but motor ran fine. A bit painful fix but not terrible, exercise cost me an hour, but next time would take maybe 15 minutes to correct. Hope this helps.
Posted on Oct 14, 2012
Sometimes the ballbearing in the shaft where you dip into the paint gets stuck .if you unscrew the end of the shaft and clean the ballbearing.then put back together and try prime again.
Posted on Apr 23, 2009
  • brendansm5 Apr 24, 2009
    ok i think you will need to unscrew the shaft, i think the ball bearing in that model is at the top of the shaft..there should be a little cup in the top of the shaft with a ball bearing in it.the ball bearing is supposed to move up and down while the sprayer is priming or spraying.some times it gets stuck from dirt particles,give it a clean and put it back and try prime again with some water.hope that helps!
Sprayer was working fine and ran low on paint and lost prime. could not get it to re-prime. now its still got paint in it and i can't get it to do anything. i need to clean it ont.
I haven't much experience with airless sprayers but I have heard the bad language from those who use them.
I expect there is still paint in the business end of the mechanism and an air bubble stuck between that and the new paint fill.
I think the sprayhead will have to be removed or dismantled so the air will be able to escape and allow priming to take place. I suggest spending a little time with the instruction manual.
Dec 05, 2015 | Titan Xl 335, xt 330 Airless Paint Sprayer
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Titan 400 wont hold a prime
Sounds like you havent got the ball bearing in the prime valve seating properly did u wash them thoroughly befor setting them in if you rebuilt yourself not a good idea will cost you arounf 400 ponds for a complete service with new piston and valves
Sep 03, 2014 | Titan Advantage 400 Airless Paint Sprayer
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Small leak from gun of titan 400 advantage
Try reduce the pressure or change the spray tip seal areyouusingthe correct size tip for the paintyou are sprsying
Jul 14, 2013 | Titan Advantage 400 Airless Paint Sprayer
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
I have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
When you switch it from prime to paint and it's still running:
- If paint/water continues to come out of the prime tube, your prime valve isn't seating properly and needs to be replaced.
- If you get a little pressure at the paint gun but it is surging, your packings, most likely the lower set, are damaged and letting most of the paint leak back past them. Packing/seal kits are available for your machine. Use all parts in the kit and grease/lubricate all of the parts well. Inspect the piston and cylinder for scoring or pitting that can damage new seals. They should be mirror smooth for proper operation and life of the seals.
Oct 28, 2012 | Titan Impact 440 Skid Airless Paint...
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
Air Tools & Compressors Logo
3,511 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
