Question about Motorola Radio Communications
How can I clean coroded battery terminal in my T289 Walkabout?
    Master:
  • Motorola Master
  • 541 Answers
Use mild abrasives, such as a sandpaper stick or emory board. Use rubbing alcohol and lots of Q Tips.
regards,
Posted on Jan 02, 2015
    New Friend:
  • 13 Answers
Try sweep with spirit solution
Posted on Oct 12, 2013
I have a Chevy hhr and there is a clicking noise when I try to start the car. Please help
If the battery is fully charged, the starter solenoid may be weak
May 16, 2013 | Cars & Trucks
Can a coroded battery end make the battery light turn on a 98 cavalier
yes it can because the cars computer is not sensing a fully charged battery & it may lead you to an undercharged battery because it is not getting it from the alternator. it takes good clean terminals on both battery & connector cables to have a healthy electrical system in your car. it's the heart feeding the veins. catch ya later.
Nov 18, 2011 | 1998 Chevrolet Cavalier
The starter was tested and came back good. When I jump the starter the van will start and stay running, when I shut it off it will start two or three times and then nothing
So that means that the battery is not recharging. Look into what charges the battery and keeps it charged?
Alternator? Regulator? Problems with the battery terminals themselves? Are they coroded? What about the terminals that connect the cable to the battery, do they need to be replaced? Are they coroded? Is the battery the type that needs water? Does it need to be filled?
Is there something else that could be causing a strain on the battery?
Jun 04, 2011 | 1998 Plymouth Voyager
I have a Norelco 4845 XL rechargeable razor that has not been used for about 8-10years. I took it apart and the batteries seem to be coroded around the terminals. What can I use to clean the terminals...
It would not be a good idea to try to use the shaver with those batteries...even if you cleaned them. If you intend to use the shaver, you should replace the batteries. You will find correct batteries at shaversource.com
http://shaversource.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Scroll down the page for tutorial videos on replacing the batteries
May 31, 2011 | Norelco Micro 4845 XL
When I try to crank my van, the lights go out and nothing happens. What could cause this?
I had this problem. Cleaned coroded battery terminals and it never happened again.
Apr 12, 2011 | 2000 Oldsmobile Silhouette
My vehicle will not start. the engine makes no sound, so what may be the problem and how do i fix it.
if you have coroded battery terminals clean them with water and baking soda and a wire brush then reconnect them and seal them with vasoline then jump start the car also if your terminals are corroded most likely the battery is shot and the alternator will burn up trying to charge a weak battery so replace the battery if bad or you will be replacing the alternator soon as well
Aug 15, 2010 | 1995 Honda Accord
Wondering about a charger
The "alkaline" version of your radio uses thee "AA" batteries and is not equipped for using a charger. Don't panic though, just visit any store with an electronics department. You can pick up NiMH rechargeable batteries and a generic charger. You have to remove the batteries from the radio to charge them, but you can always keep an extra set of batteries charged and ready for use.
Nov 21, 2009 | Motorola Talkabout T289 (14 Channels)...
How do I open my Motorola talkabout T289 to replace the batteries ? Thank you
The black U-shaped sides, which are attached to the back, slide down and off the radio as one piece.
Aug 09, 2009 | Motorola Talkabout T289 (14 Channels)...
Radio Communications Logo
79 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
