Harman kardon hkts200sub no power - Audio Players & Recorders
5 Suggested Answers
im4um2
  • 77 Answers
SOURCE: When I go to power
Depending on your ablilities there might be a quick fix. It sounds like the contacts in your on/off switch are either corroded or worn out due to heat. Ensure the unit is unplugged from any electrical source. By opening up the unit you will have to detach the on/off switch, and by bending the prongs carefully, open the casing up. Clean all internal part using contact cleaner. If the contacts are worn or corroded, you can try replacing or what I did was added some solder to the contacts and put the unit back together reversing my steps.
Good Luck.
Posted on Jun 27, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
caroldon
  • 17129 Answers
SOURCE: my Harman Kardon HS 250
Possible that the microprocessor stage is not working and is not conveying any display to the unit.
remove the cover and check the 5Volt rail to the mP section. If the voltage is absent check on the 5 volt regulator.
If present and there is no life, then check for oscillatiion of the crystal, might need a CRO to confirm if the mP is working or the clocck signals are present, if data tranfer is present. If not mP is faulty.Take help to confirm and find a source, might be approach Harman Kardon.
Posted on Aug 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: harman/kardon avr 110, cuts off
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 29, 2011
Can i bluetooth pair my harman / kardon stand alone speaker with my ps3?
Harman Kardon AVR products and how to connect to devices
? 6:02
https://www.youtube.com/watch?v=3aPKTDlOlf0
Mar 11, 2010 - Uploaded by hyperconnected life
What I originally wanted was to have a bluetooth microphone that ... I have the av 1700 with harman Kardon ...
Esquire - Harman Kardon
www.harmankardon.com > Wireless > Portables
Harman Kardon
Rating: 4.7 - ‎16 reviews
Esquire is a Bluetooth®-enabled speaker with a built- in conference phone system ..... the sound will bounce and the bass gets a little nicer...but stand alone in the ... able toconnect it to my iPad Air as of yet; it will not recognize it on Bluetooth.Missing: ps3
[PDF]Owners Manual - Onyx Studio - Harman Kardon
br.harmankardon.com/...//harman-kardon/.../Owners%2...
Harman KardonBluetooth pairing mode automatically when it is turned on. NOTE: The speaker's Bluetooth device name is HK Onyx Studio and password is 0000. Introduction ...Missing: alone ‎ps3
Dec 16, 2015 | Audio Players & Recorders
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
I need the whole printed circuit board of the power transistors for my AVR 200 Harman Kardon receiver ? Any available ?
Not unless you can find them second-hand somewhere. Harman-Kardon doesn't supply boards as replacement parts.
Mar 22, 2013 | Harman Kardon Audio Players & Recorders
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
Harman kardon avr 100 no power
check the fuses it help the power !
Jun 07, 2010 | Harman Kardon AVR 100
I need the power adaptor but harman kardon site is out of stock
we are not a parts provider, but Radio Shack makes universal power adapters that should work.
Sep 27, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Dec 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
107 people viewed this question
 Grubhead
Grubhead
