Question about Transcend StoreJet 25 750GB USB Hard Drive
I have 750GB Transcend hard drive and currently facing following problem: 1. It is responding very very slowly. 2. It shows 250 GB has been used but physically I found only 36 GB while I enable the hidden option of my win 32 xp or win 64 win 7 system. 3. when I would try to copy files from this hard drive and paste into my computer is says "source file could not be found" 4. I have tried to scan it with kaspersky antivirus but responded very slowly and completed after long time with only 5650 files scan for "custom scan' and 25000 files scan for "full scan".
saqeb
  • 47 Answers
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Posted on Jan 28, 2009
mayur_best
  • 25 Answers
SOURCE: Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Posted on Jan 29, 2009
SOURCE: I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Try formatting the drive using NTFS and re -copy your stuffs again. If it fails to copy as you want, then delete the partition and format it again .
Posted on Mar 26, 2009
softwareguru
  • 78 Answers
SOURCE: Problem with transcend jetflash -8 gb " files in unknown format"
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
Posted on Jan 03, 2010
jomabug76
  • 1148 Answers
SOURCE: my external hdd transcend 320 gb storejet is very slow while copying file to or from the hd and the blue LED keeps on blinking what might be the problem??
Well u may have it plugged in USB slot but needs to be USB 2.0 .if in regular. USB..will run slow...also external he'd when u not using. It unplug. From USB and AC plug...not good to just let run..they will were out..defrGment hdd to.good luck
Posted on Dec 21, 2011
Testimonial: "thanks Josh.. appreciate ur help"
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
May 03, 2014 | Transcend StoreJet Computers & Internet
How to change transcend external harddisc fat32 to NTSC
HI you mean NTFS if YES, then there is step for xp or win 7
1. click Start, click Run, type cmd, and then press ENTER.
2.In the command prompt window, type: convert drive_letter: /fs:ntfs
Regards,
Chandrakanth
Oct 07, 2012 | Buffalo Technology 250GB USB SATA 2.0 HD...
Describe your Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Problem
I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
dearme9@yahoo.com is my mail and this is banner i see.
Jul 26, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hard disk transcend 250 gb storejet isnt oening and not even detecting in vista and windows 7 and also in xp how could i open it
You may just using just a data usb cable on your hard disk. Try to get usb cord with data and power cable (combo) and check if this resolves your concern.
Hope this helps.
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
When i check the properties of my transcend 160gig it says there is 39gigs used space however when i look at the files through my computer it only shows 1 file . how do i view and access the other files...
Click the start button in windows and select support and help tab.In the search box type show all files or hidden files then follow directions.Hope this helps
Apr 27, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My Transcend StoreJet 320 GB USB 20 Hard Drive is having a problem When i connected the drive to my laptop it got detected for sometime and then disconnected automatically
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 25 750GB USB Hard Drive Logo
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
