Question about HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX
Fuser error on Hp 400 printer - HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX
Soulvisitor
  • 1113 Answers
SOURCE: HP LASERJET 4250n PRINTER-PROBLEM WITH PAPER JAMS AND "FUSER ERROR"
Put a maintence kit in your machine, easy install, everything just clicks in, Every 200 000 prints it should be done, it includes the fuser, all feed rollers, sep pad and transfer roller.
These are great printing machine, they only ever need the MK and on this model a fuser drive gear wears and get noisy, but once that has been done once, it is ok from then on.
KIts seem expensive but they are meant to last 200 000 prints and usally do. These are one of the best most reliable printers in the market.
fee693c.jpg LINK to part info
Posted on Jan 09, 2008
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Posted on Mar 28, 2008
  • 10 Answers
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
Posted on Oct 22, 2008
MightyFalcon
  • 32 Answers
SOURCE: 50.4 fuser error
     This fuser error can lead up to a series of solutions, and I will list them in order of easiest to hardest.
1) Unplug your printer from the wall, wait 5 minutes and plug it directly into the wall, UPS battery backups and Surge Protectors can trigger this type of error.
2) If you have another one of these printers, try swapping the fuser roller with another one while the power is off and see if the error persists upon startup.
3) Last and least desirable, you may have a failed Engine Controller Board, which is responsible for among many things, making sure the fuser is at the proper temperature and has no tears. Be aware that this repair requires a pretty serious disassembly, and can be daunting to a newcomer.
     The fuser is actually considered a part replaced with routine maintenance, around every 100,000 to 150,000 pages. It is what is responsible for the carrying the charged toner particles and heating them up to melt them onto the target paper (New HP Laserjets use a wax based toner for better environmental impact) Problems with the fuser generally show themselves as lines or splitting images on printed paper, but if serious enough (as in a tear on the roller) can cause the printer to cease printing to prevent serious damage to the interior of the machine.
Posted on May 06, 2009
Fix the 50.3 fuser error laserJet Pro 400 M401dne?
Use you computer search engine and type in "Maker Model (of printer)user manual" . It will bring up sites to get manual.
May 18, 2016 | Office Equipment & Supplies
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
What is the solution for fuser error 50.4 in laser jet pro 400
Most likely you will need to replace the fuser. Try plugging the printer in to a different outlet than it is right now. If you get the same error then you can be pretty sure the fuser is bad.
Feb 20, 2015 | Laser Office Equipment & Supplies
How do you fix a 59.3 error
59.3 indicates the fuser motor is not starting up.
This usually means the fuser motor needs replaced.
Part Number RM1-8609-000CN
Mar 13, 2014 | HP LaserJet Pro 400 color M451dn - Printer...
My printer hp laser pro 400 show message 50.3 fuser error
hello ,,
50.x Fuser Error
Description
The product has experienced an error with the fuser.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
Turn off the product, wait at least 25 minutes, and then turn on the product.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support.
Oct 21, 2013 | HP LaserJet Pro 400 M401DN Laser Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet Pro 400 color M451dn - Printer - color - duplex - laser - Letter/ Legal - 600 dpi x 600 dpi - up to 21 ppm mono / up to 21 ppm color - capacity: 300 sheets - USB/ 10/100Base-TX Logo
419 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
