Question about Kenmore 62802 Electric Dryer
Dryer won't stop running - Second try
The dryer doesn't stop running. It just continues to cycle through the off position and starts going again. Opening and closing the door does not reset it. Normally need to push the start button to start it up again but it runs whenever the door is shut (unless it is in the Off position). We have to leave the door open to keep it from running. Thought it was the timer and just spent almost $80 for the part but that wasn't the problem and now I'm stuck with it. My guess it is either the push start switch or the door switch but I'm looking for advice before I start replacing any other parts. Thanks.
  • Joe McLeer Sep 28, 2007
    I put in a new push-to-start switch last night and that seems to have fixed the problem. Now when I open the dryer door during the drying cycle and close it the dryer does not start running again as it did. I have to push the start button to get the dryer to start up again. Thanks.
  • 290 Answers
The push-to-start switch is the easiest and cheapest to replace. You can check it by starting the machine then, unplug it, remove one of the wires from the switch, then plug dryer back up. Dryer should not start. If your model has an even heat board and two relays under the console, your problem could be with them if switch is not bad. Reply back if you need to know how to check them.
Posted on Sep 25, 2007
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Won't start and overheating
Hi Beverly Johnson...
Your problem is possibly a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Sep 19, 2012 | Whirlpool Dryers
The dryer won't stop running after a heating
Hello, Thank You for using FixYa. I will be helping you today.Replace the timer.It has a bad contact.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Kenmore 64882 Electric Dryer
I have a 4 yr. old kenmore elite HE4 dryer. I put the clothes in and hit normal cycle. 41 minutes automatically comes on. I hit various buttons and nothing happens. I hit the start button and it finally...
if I am understanding the problem correctly then this website should work, if I am misunderstanding then the second one might help.
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~3088/forum_id_~409
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 03, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Imtermittent Dryer Start, Stop Problem
Motor is BAD !!! Replace it.
Please rate This !!
Sep 10, 2008 | Kenmore 62602 Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62802 Electric Dryer Logo
305 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
