Question about Miller Welding Tools
I have a miller generator/welder and the starter stays ingaged after starting. The ignition wire to the starter has twelve volts to it contuniously. I followed the wiring diagram and descovered a diode conected to that wire and replaced it and no change. I cut the diode out of the wire and it solved it. But at the same time of this problem accured, the welder would not idle downn when not welding as it normally does. Both these problems accured at the same time so the most be caused by one issue?
  • arbeyette Apr 24, 2009
    thanks fixer1950 diode was in backwards
    President:
  • 2,976 Answers
Put the diode back in but check the polarity. If removing the new diode corrected the problem, the new diode was in backwards.
Posted on Apr 23, 2009
I JUST BOUGHT A 2003 TRAILBLAZER 301G AT AUCTION AND DONT KNOW ANYTHING ABOUT IT . IT WILL RUN BUT IT SOUNDS LIKE IT IS RUNNING WAY TO FAST AND WANT IDLE DOWN . I TOOK THE TOP OFF AND ITS GOT 3 OR 4 PLUG IN WIRES UN PLUG , THEY ARE RIGHT NEXT TO THE COMPUTER BOARD RIGHT BEHIND THE CONTROL PANEL . IM SCARED TO PLUG THEM UP BECAUSE SOMEONE UNPLUGED THEM FOR A REASON . THANKS BOBBY
Posted on Jun 29, 2012
Miller bobcat 225 wont crank replaced bayyery, starter and switch where should i go from here?
Check to see if the starter solenoid turns on a 12 volt test light when the ignition is held in the crank position.
Nov 02, 2016 | Miller Welding Tools
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
How to connect welder to a portable generator
There are many adaptors , form generator to other connectors, go to Ebay find out which one you need, most hardware stores have converter cables from generator to what you need, most adapters covert 240 to 120v 30 amp or 15 amp or 30amp to 50amp!
Apr 07, 2017 | Diesel Miller 907218 Trailblazer 302...
Miller cricket 115 volt wire welder stock #909071. plug it in, it starts feeding wire...even when switch is off. where do i look?
The contactor is stuck closed, the trigger wiring in the cabinet is shorted together or trigger switch stuck closed.
Jan 09, 2012 | Miller Welding Tools
I replaced the starter in my 04 Honda Accord, but it still wont start. I was wondering if there is a fuse for the starter that may have blown?
You need to check for twelve volts constant at the large wire and twelve volts in the start position at the small wire, I'm guessing you are missing voltage at the small wire and the maybe caused by a blown fuse,bad ignition switch, or an aftermarket or factory alarm system that is not disabled
Jul 31, 2011 | Honda Accord Cars & Trucks
What is the correct gas for miller renegade 180 weder generator mig
Depends on the application and type of wire you are using. If you are using flux cored wire you want Co2. If you are using mig wire 75/25 blend (Argon/Co2) would be my choice. Your wire should also give you a recommendation of which type to use.
May 07, 2010 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
370 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
