Question about Yard Man Mulchinator QuickShift BlowerVac Yellow
Yard man model GBV3100 how to replace primer bulb
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
Craftsman trimmer #358798420- can't remember how to put fuel lines back on the carb & primer bulb.
Is this question for a mower or a trimmer? If for a mower there is only one fuel line. If it is for a trimmer, there are two fuel lines. One goes from the filter in the fuel tank to the carburator primary inlet. The other goes from the primer bulb to the tank and is the return line. GOOD LUCK.
Jul 26, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Fuel line routing yard machine 31cc cultivator 21A - 120R000
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Apr 29, 2010 | Yard Machines Cultivator
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Gas leaking in a stream from other end of primer line
Something is causing the float in the carb to stick in a downward position. This float tells the carb when to cut off the flow, and stuck down it keeps the channel open for gas to flow through. Empty the gas and remove and thoroughly clean out the carb, making sure you hit the float bowl very well. Worst case the float could be bad. If cleaning it thoroughly doesn't get it, consider a carb rebuild kit from the engine manufacturer or replacing the carb.
May 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yard Man Mulchinator QuickShift BlowerVac Yellow Logo
Top Yard Man Garden Experts
Richard Schanie ...
Phil Walker
Phil Walker
itsman
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
