Question about Kitchen Ranges
8114p471 60 jenn air
The stove works, but oven does not. Thinking it's the control board? Need to make sure I have the correct model number to order a new one
SOURCE: Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Posted on Aug 25, 2008
  • 121 Answers
SOURCE: Jenn Air model S176W
Unfortunately whit the technical comes technical problems. Circuit boards are repeated problem in my profession. Replacing the circuit board will fix the oven, but also inspect the door gasket to insure a tight fit. Depending on the age and condition of the oven you may consider replacement.
more asst.
eboukater@gmail.com
Posted on Sep 24, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
yecalam13
  • 41 Answers
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Posted on Jul 24, 2009
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Posted on Aug 12, 2009
I have a jenn-air electric down draft slide in range. I had a power outage and now stove top works fine but no display or oven functions not even oven light.
You will need to replace the control board (clock assembly) on your unit. I see this all the time with power surges and it takes the control board out. Your model is a discontinued one and the part may need to be a special order. Here is a link to the part, call the number that is on the page and I am sure they may get it for you.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-clock-item-number-ap4088717.aspx
Nov 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
F7 is beeping constantly...fan is also running
We had a similar issue. I assume you have the touch pad keyboard. If you clean this with a rug that produces static it will cause a problem with the touch pad. I replaced ours and it is now working again. You can get this part at repairClinic.com. Our p/n for this was
1008902 Touchpad & control panel assembly (Black) 1 $173.10 $173.10
but make sure you check for the correct part/number to fit your oven! Make sure you disconnect power from the oven before you disassemble anything!
I was very happy with the service from repairClinic.com. I can highly recommend using them!
Dec 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air 48600 touch button problem
Hey Erik,
Thats was happening to my sisters jenn aire just a couple monthg ago. I ordered a board for it but, the daybefore it came in I jauseled the front of the board attachment piece and made sure all connections we're tight... yada... in the maint field... you know hand search all connections with these printed led boards you can just have a loose connections and send bad signals and false board readings. And yes, even touch pads willact weird. So good luck, worked for me!
Pete
Dec 22, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Heat and moisture (steam) kills the electronics in any control. but if the mark are on a circuit then there was a short in a circuit. I would check the series if your stove( first two numbers in the serial number)if it is a early series. for sure that they have make improvements in the control. And a Replacement controls will have all the improvement and revisions. good luck and let me know what you do..kraztech
Sep 07, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
