How we can set password toshiba e studio e 212
4 Suggested Answers
  • 20 Answers
SOURCE: Toshiba e studio 212 copier. Gives error code e03.
Search carefully onto the fuser cover for the actuator for exit sensor.
There is a spring that moves the actuator into normal position when the paper has passed. If it seems the spring is out from the actuator it will think there is still a paper jam. The best bet would be to call a service company to come out and make repairs if you are unable to get this spring back into place. After resetting the spring into the correct location, restart the machine and see if the problem continues. If it works and then goes into error mode again, it is likely this spring and or senor will need to be replaced.
Good luck.
Posted on May 13, 2014
  • 86 Answers
SOURCE: Toshiba e studio 212 . After replacing lithium
have you tried to remove battery and wait 30 seconds then reinstall...see if this helps...
Posted on May 20, 2014
mileso
  • 3320 Answers
SOURCE: Toshiba e studio 212. Error message E03 comes. I
Read this Toshiba Studio 182 Error Codes Free downloads
Posted on May 23, 2014
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
Toshiba e studio 212 photocopier machine change the toner but massage low toner
The toshiba machine e studio 212 is zerox actual image on in side tray but we are select out side try the image is shifted on output paper.
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
15 people viewed this question
k24674
jasbo
jasbo
