Question about DISH Network ES188454 Stand For JOEY Thin Client Receiver ES188454
Dish joey will not work when hdmi is run though Yamaha av reciever
How do I hook up my Joey dish network to audio video modulator
Hi Tammie, my name is Kimberly and I forma part of the Social Media Department with DISH. I Apologize for the delayed response. I hope this answer helps you in the future or can help someone else that may have the same question. In order to hook up a Joey to Audio all you need to do is make sure you will be connecting the Joey's output into the Audio's Input. For example if you will be connecting the joey directly to the Tv, using an HDMI cable, the Joeys Output for HDMI has to simply connect into the Input for HDMI on the Tv itself. Feel free to reach me at: kimberly.escobar@dish.com with any questions or concerns.
May 09, 2013 | Televison & Video
Yamaha rx-v367 and internet tv audio
try connecting the hdmi out from cable box to your tv hdmi input, and leave the hdmi out from tv to the reciever where it is, leaving reciever selected to 'TV' and yes, a sub matters (it is not part of your problem but you need the bass a sub provides)
Mar 05, 2013 | Yamaha RXV367 Receiver
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I have a Pioneer reciever that does not have a hdmi input, also There is 1 optical input on it that my cable box is hooked up to. I have not opened the ps3 yet because I'm not sure how to get the sound to...
ps3 comes with an av jack set as well as hdmi. now you can use the hdmi to the TV and run audio out from the TV to the receiver and that should work but if you don't have audio out on the TV then you need to go get the av cable
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
Let me be more specific on our problem. We installed the reciever according to directions. The 2 questions are: first, we have Dish Network. Isn't it possible to watch tv with the Yamaha reciever off with...
Look towards the back of the manual. You go into setup. Choose HDMI. Then there is another setting that you have to activate. The receiver must be set to the HDMI input that you want, before the receiver is turned off. I just installed my receiver last night and followed that procedure. Works great.
Oct 11, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
DVD picture flashes on & off
our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Dec 16, 2007 | Toshiba SD-6000
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
DISH Network ES188454 Stand For JOEY Thin Client Receiver ES188454 Logo
18 people viewed this question
Top DISH Network Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DISH Network Audio Player and Recorder Expert? Answer questions, earn points and help others
