SOURCE: There's an annoying beeping sound everytime i
Possible your filter is getting clogged or your water inlet is slow; possible i repeat. Check this out:
Remove the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there, it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. A nice rating if helped pl.........
SOURCE: whirlpool duet won t spin continues to beep and
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: whirlpool duet wash machine, beeps and displays a
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
SOURCE: my whirlpool duet is very annoying. I think the
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
