Question about Mr. Coffee TFX20 / TFX23 Coffee Maker
How to clean a coffee pot with viniger??
I'm not sure how to do that.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Try 1 cup viniger fill rest of pot with water. run it through the machine. through away fill pot with water run through 2 more times. that should do it.
Posted on Apr 24, 2009
My Cuis/keur barely drips out any coffee. This started several days ago. I cleaned it out with vinegar, and cleaned both spikes. It worked fine for a few days. Now it's barely drips out any coffee.
If you have hard water it's most likely still plugged with lime and calcium build up. After vinegar got though did u let it sit for a bit before rinsing the brewer with fresh water and was it brewing normal. If so then I'm guessing it's got stuff plugging it still an may need to be delimed several times if the vinegar was still in system from not enough fresh water rinsing I bet after sitting when u turned it on to brew a few small pieces got pushed though and plugged brewer again. Buy some CLR and run it though. Just make sure you rinse a lot of fresh water though. That's what we do for our commercial air pot brewers when they get plugged. Just keep trying the deposits should break down and finally work it self out with CLR or viniger. Hope this helps
Nov 10, 2016 | Coffee Makers & Espresso Machines
I need to know how to clean my coffee pot.
The pot or the whole coffee maker?
The pot you can wash with dish soap and warm water. Rise really good. If you want to clean the whole coffee maker you can fill your coffee pot with about 1/4 cup of vinger and the rest water run that through it and after that has run then run it 2 more times with just warm water to make sure all of the vinger is out.
Mar 09, 2016 | Coffee Makers & Espresso Machines
Coffee drips how do you clean reserve
Fill the pot with viniger at least up to half, Pour it in the researve tank end let it go though as if your makeing coffee with it, Do that 2 times, Then after it is finish doing the secound pot,leave it in for 30 minutes. Dump it out, Then do the same (Again) But use (water) to do it with, Once the .2 pot of water have gone though it ,then it is ready to use again, this should claen it up for you.
Oct 26, 2012 | Cuisinart Coffee on Demand 12-Cup...
What home product can I use to descale
I have run 90% white viniger mixed 10% with water in my coffee maker.Run the mix several times trought the coffee maker, then run water to remove the viniger tast.
Dec 28, 2010 | Braun Tassimo Coffee Maker
How to clean
Clean just like a coffee pot. Fill with white viniger, let heat up, press the steam button a few times to be sure viniger is in the holes. Now turn it off, place it in its rest position and let sit for an hour or so. When you are finished empty it out and rinse a few times with regualr water until there is no more viniger smell.
Nov 25, 2010 | Westinghouse WST5017 Iron
Water does not seem to be getting to the heating area
I'm not sure if your saying it does not brew a cup of coffee at all or it is brewing but only cold water comes out. If it is just sitting there making a whinning noise and not delivering water it may just be dirty. To clean it you need to fill the resivior with a 50% white viniger and 50% water mixture. Run a brew cycle and let it sit for an hour. Then run several cycles through until it is out, refill the resivior with water only, run it completely through and continue with the water only until there is no more viniger smell or tatse. You will need to clean the brewer needle heads as well. Lift the handle to access the coffee pod compartment, remove the pod basket and use a paper clip to clean out the hole in the puncture needle. With the lever still raised, use the paper clip to clean out the three holes in the upper needle head. Replace the pod basket, close the handle and run a couple brew cycles through without a coffee pod.
Nov 24, 2010 | Keurig B100 Coffee Maker
How do I clean the heating elements in my swan tea kettle. it looks like a mineral build up on the elements that comes off when the element is hot and the minerals fall into my tea water
IF THE BUILD UP OF SCALE IS BAD YOU MAY HAVE TO TREAT SEVERAL TIMES TO CLEAN. VINIGER IS A GOOD CHOICE, JUST FILL ABOVE THE COILS AND LET SIT AND DO THIS AS MANY TIMES AS IT TAKES TO CLEAN THE COILS. ANOTHER GOOD PRODUCT IS CALLED- CLR MOST HOME DEPOTS HANDLE THIS PRODUCT IT STANDS FOR C-CALSIUM / L- LIME / R- RUST
THIS IS A LITTLE STRONGER THEN VINIGER BUT DOES THE SAME THING. BOTH WILL TAKE SEVERAL CLEANINGS
Sep 05, 2009 | Swan Kitchen Appliances - Others
HAVE LOST MANUAL. HOW DO I CLEAN IT
You will need the de-liming tool to proceed. Run a pot of white distilled viniger thouth the coffe maker. Viniger is a excellent cleaner & will not hurt any internal parts.
Jul 28, 2009 | Bunn 10 Cup Home Coffee Brewer
My stay or go coffee maker. When I try to make a full pot of coffee I only get half a pot I push it on again and still only get a little bit more coffee. I have to start up about 4 times to get a full pot.
Try cleaning out the water system, it may need to be descaled, buy the descaler from the supermarket, follow instructions, make sure machine is well flushed out with clean water after cleaning operation.
Jul 07, 2009 | Hamilton Beach Stay or Go 45234 Coffee...
Mr. Coffee TFX20 / TFX23 Coffee Maker Logo
116 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
