Question about Apex Digital New Original Apex LD4077M Remote Control
Apex ld4077m remote code - Apex Digital New Original Apex LD4077M Remote Control
Will not come on
First make sure there is power in the socket you are plugging the unit into. If that's OK and the unit has been plugged in then 1) Disconnect the TV from the power by unplugging it from the wall socket. 2) Wait 20 minutes and then plug it back in. 3) Turn it on and see what happens.
I've seen a number of LCD TVs some back to life if these three steps are taken. It allows the TV to reboot itself after all internal capacitors are discharged.
Mar 24, 2015 | Apex Digital Apex 40" Class 1080p 60Hz LCD...
Where can I get a replacement screen for my apex LD4077M
Samsung outlet should be able to come up with that.
Aug 09, 2014 | Televison & Video
I need 9 digit antenna code for Apex LD4077M to hook up antenna?
Most likely code: 10767
Others to try: 10765, 10748, 10879, 10890, 11991, 10889
To program your Comcast remote:
  1. Turn on the TV or other device that you would like to program.
  2. Press the TV button on your remote control.
    NOTE: If you would like to program your remote control to work with a DVD Player, VCR or Audio device press the AUX button.
  3. Press and hold Setup until the red light blinks twice, then release Setup.
  4. Enter the first code for your device listed above. If you perform this procedure correctly, the red light will blink twice.
    NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 4 with a valid code.
  5. Aim the remote control at your device and press Power once (press the Play key for devices that don't have a POWER button). If the TV turns off, make sure that the VOL+/- and Mute buttons also work. If so, you're all set!
  6. If not, repeat these steps using the next manufacturer's code (you may need to try several codes to find the one that works).
Aug 04, 2014 | Apex Digital LD4088 LCD TV
Program Code for xfinity remote with red botton
0256,0255,0251. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 13, 2014 | Apex Digital New Original Apex LD4077M...
Cannot connect my Apex LD4077M to comcast. What re the codes for the remote? johnagnew86@comcast.net
0092,0096,0097. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 19, 2013 | Televison & Video
My remote doesn't work
Do you have any flashing indicator lights on the remote? If you don't you can verify your remote is sending IR signals by pointing a cell phone camera at the front of the remote and viewing through your cell phone screen while holding down a button on the remote. You should see the flashing IR light on your cell phone screen. If you do not see the flashing light either the batteries are no good, or the remote is not getting power due to a problem with the circuit board.
Nov 23, 2012 | Apex Digital Apex 40" Class 1080p 60Hz LCD...
Apex codes
Hello
You are seeking codes with RCA systemlink-3 remote control to Apex TV. Unfortunately, there is no setup codes for Apex Tv with this remote control. It is very difficult to gat a remote control that has setup codes for Apex Tv.
Comcast On demand custom-3 universal remote control has codes for Apex.
Codes are :
0748, 0765, 0767
OK.
Oct 25, 2011 | RCA 3-Device Universal Remote
We are trying to program the APEX TV code into the Dish network remote and none of the codes in their book is working.
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. In order to address your remote to your TV you are going to need the model number of your DISH remote. The model number will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes as well as the instructions for addressing your remote to the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dishnetwork.com. Thanks.
Remote model # Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 745, 743, 744, 595, 757.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 595, 743, 745, 757.
4.0 and 4.4 IR/UHF remotes - codes 744, 595, 745, 757.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 744, 745, 595, 785, 743, 757.
20.0 IR and 21.0 IR/UHF remotes - codes 552, 594, 815, 595, 743, 757.
Instructions for addressing the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 26, 2011 | Apex Digital LD4088 LCD TV
Apex Digital New Original Apex LD4077M Remote Control Logo
35 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
