Question about Kodak Office Equipment & Supplies
Slide carousel rapide speed
I have a Kodak projecter 600 carousel When you start it the slides go so quickly you can't view them. Anything I can do. Tha select button does't seem to engage. I have no manual, does Kodak offer them online?
thanks
    President:
  • Kodak Master
  • 412 Answers
The problem is caused by a mis-adjusted clutch contact. This adjustment requires some dis-assembly, so unless you have service manuals for the Carousel 600, I would recommend you find a factory-trained repair dealer.
Posted on Jan 04, 2011
Www kodak com go support
Manufacture date for a Kodak easy share z712is
Aug 26, 2014 | Kodak Carousel 850h Slide Projector...
Slide continuously change
The clutch contact on your KODAK Carousel 600 Projector has either burned off from use (the projector is almost 50 years old) or is out of adjustment. Either condition will allow the continuous cycle to happen. Because of the projector's age, parts will be really tough to come by. I have attached a diagram to show you what the affected parts look like. Be sure to take extreme caution - - there is exposed electrical contacts all over with the bottom cover removed. Also, be sure to remove the lamp and all optics before starting this repair.
Jan 17, 2014 | Kodak Carousel 600 Slide Projector
Kodak carousel 760h projector
The problem you described is a timing issue with the Slide Change Mechanism. The timing changes (most often) due to wear. Because most Carousel 760H's are about 40 years old, this is the most likely cause. You should enlist the help of a trained technician to make this adjustment on your behalf.
Dec 24, 2013 | Office Equipment & Supplies
Can I advance my slide tray manually?
A Kodak Carousel 600 has no Forward/Reverse buttons for tray movement. The only way to advance the tray with the slide change mechanism is by LIGHTLY depressing the SELECT bar. To manually advance the tray, push and hold the SELECT bar down fully.While holding the SELECT bar, you should be able to rotate the tray by hand. Good Luck!! Jim
Aug 08, 2013 | Kodak Carousel 600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Kodak carousel 600 slide projector thermal fuse replacement
If the FUSE is still available (this model could be as much as 50 years ago!!), the fuse is wired into the 120 volt circuit near the projection lamp. Check with: www.micro-tools.com
for availability. good Luck!! Jim
Feb 22, 2013 | Kodak Carousel 600 Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
My Kodak 800 carousel projecter will not select slide into viewing position or rotate
Terry,
Glad the cycle solenoid solution helped identify the problem with the Carousel 800! Let me know if I can assist with anything else, and if you are able to get the 800 fixed!
Jim
Sep 30, 2011 | Office Equipment & Supplies
120 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
