Question about Sole Fitness Exercise & Fitness
Sole f63 treadmill just assembled and humming after turned on.
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
SOURCE: Sole F63 slows down and
I got the same problem. Thinking about cleaning the speed sensor. Ever figure it out?
Posted on Feb 05, 2011
  • 33 Answers
SOURCE: Our Sole F63 treadmill is
pls make clear , countdown is come or not, if coming means problem with controller
Posted on Feb 19, 2011
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: sole f63 key
please download the owner manual from www.fitness.manualsonline.com and see the section how to assembly and reverse and proceed according.
God bless you
Posted on Dec 18, 2012
My sole F63 treadmill is stuck up in the storage state. I tried to use the yellow lever and it isn't lowering and I can not use it!
Lift the treadmill slightly to take pressure off of the locking pin as you work the release lever.
Oct 08, 2014 | Sole Fitness F63 Treadmill
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Why wont my sole f63 treadmill incline?
Are you getting a reading on the display? Are you getting a incline error?
May 09, 2014 | Sole Fitness F63 Treadmill
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
Aug 05, 2017 | Sole Fitness F63 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
Sole f63 key
God bless you
Dec 17, 2012 | Sole Fitness F63 Treadmill
My sole f63 wont fit through the door, how can i take it apart?
see the video attached and proceed according. God bless you
Other alternative is your read the instr. manual and follow the section how to assembly or disassembly your treadmills.
Dec 06, 2012 | Sole Fitness F63 Treadmill
Exercise & Fitness Logo
26 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
