Question about Kenmore Elite 45986 Front Load Washer
My front loader washing machine is level, but it makes a lot of noise and travels all over the floor. What is wrong with it?
  • 113 Answers
Be sure your clothes are not off balance
Posted on Apr 23, 2009
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Dec 11, 2016 | Baumatic Washing Machines
I just bought a basic kenmore top loader washer where the lid locks when it washes but when it washes it makes a saw noise is that normal
Was this installed by yourself? Does the machine sit level on the floor? Washing machines should not make excessive noise when being used. You should not use it and immediately contact the supplier.
Mar 04, 2015 | Kenmore Washing Machines
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
Trouble balancing a used neptune front load washer
It might not be the leveling of it. Front load washing machines have a lot of power when they go into their spin cycle. Depending on your floor and if the washer is upstairs it is going to shake and make a ton of noise. When I worked for Sears as a tech I had to explain this to a lot of people that just got their first front loaders. Some of them would say that it sounded like a plane was flying threw the house when it would spin. Others said it was like an earthquake. Front loaders don't work good in mobile homes either. Not saying that you have one. Anyway, when these go into spin the have so much force coming from them and all that force goes straight to the floor. If your floor is weak or that washer is in a spot where it is weak it's going to shake. The best thing to do is go under the house and put in a support beam right under the washer. This will get it to lighten up a bit and maybe even fix all together. Give that a try and see how that does. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Out of balance drum WM2277HW?
More than likely it did not get reinstalled right after the move. All four of the leveling legs must be firmly touching the floor. If one is even the thickness of a piece of paper off the floor it will start to rock during spin and the problem just amplifies itself. Make sure it's perfectly level and that all the feet are firmly on the floor.
Jul 28, 2008 | LG WM-2277HW Front Load Washer
Whirpool top loader unbalanced spin cycle
First change the springs - both the leveling and suspension. You may also need to change a few other parts on the brake and drive tube including the thrust ring. But replace the springs and let see what happens.
Post your results . Remember to rate this solution
Regards
Jul 27, 2008 | Whirlpool LSB6200KQ Top Load Washer
Front loader washing machine
Plug off the wall; open up behind. Possible some spring hs come off or a shock absorber is faulty. Can be easily fixed by you. You might have to take the top off.
Jan 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
