Question about All Grip Seat Cover - 2003-06 KFX400, 03-10 LT-Z400
My 2005 kfx400 will only start by push starting and wont idle?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Take it into a shop , or if your confident then you can do it yourself. It seems to me that if it will not idle and is having troubles starting then your intake or exhaust valves need to be adjusted.Over time your valve stems stretch based off of the metal alloy in them some need adjusted more often and some need adjusted less often. I am 80% positive that this is your underlying issue. I have encountered this at least 10 times.
Posted on Oct 12, 2013
Is the choke on in the up or down position crf 150 f 2005
try in both positions when trying to start it,kick it a couple of times in the up position if it starts and idles a little high then choke on,then push it down while running,if idle smooths,then choke is off,may have to do it couple times,but you will be able to tell the difference.
Feb 24, 2011 | 2005 Honda CRF 150 F
My 2005 Colorado RPM's fluctuate on a cold start up, from normal down to 500 Rpm. The truck starts fine, but as soon as I have to push the clutch in and stop, the Rpms will fluctuate about 3x and then it...
eddyblueange_2.jpgthis is an idle valve after 1996 the ecu control the idleing from the engine with this air by pass if this valve is geting bad it can get stuck open or closed or dont working right is an electric selenoid ......... listen for air leaks ....... wen you push the clutch you push the brake too check the brake booster
Dec 28, 2010 | 2005 Chevrolet Colorado
Drove 1991 gmc sonoma 1700 miles and now it wont start or idle...
check the play in the distributor,and check that the fuel pressure is normal
Aug 19, 2009 | 1991 GMC Sonoma
Engine hard to start wont idle sometimes wont idle down when shifting or stopsd
Won't idle down: look for dry/rusted/frayed inner throttle cable. Look for sluggish fuel flow from tank for starting problem. May have to clean the carburetor(s) and fuel filter. Are the spark plugs clean and gapped correctly?
Aug 18, 2009 | 2005 Buell Blast
I have a 2005 yamaha venture royal star and i just replaced the iginition coil on the rear left hand side due to weak spark. The new coil seemed to have a lot more spark (maybe too much). The bike started...
If it wont do anything then it is likely that youve popped a fuse
But it sounds like the battery isnt being charged properly. Make sure the voltage across the batt terminals is at least 13.5v at tickover rising to no more than 15.5v at higher revs
Ride-Safe
Bike-Doc
Please mark this as helpful (if it has been!!)
Aug 14, 2009 | 2005 Yamaha Royal Star Venture
When i push my 125 it sounds like its started but it wont start.y
when you push your bike the engine is turning over and it will sound a bit like it is running only not as loud. This is a 2 cyle engine right? do you eventually get it started ? If not try cleaning or changing the sparkplug, they foul easily on 2 strokes
May 08, 2009 | 2005 Honda CR 125 R
2005 CRF450R Hard to start and wont idle
Hi
I would suggest that you have the valve clearances checked.
Also, check that the carb is clean. Pay particular attention to the PILOT JET as this opperates the idle circuit.
Jon
Mar 03, 2009 | 2005 Honda CRF 450 R
All Grip Seat Cover - 2003-06 KFX400, 03-10 LT-Z400 Logo
66 people viewed this question
Top Factory Effex Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Factory Effex Vehicle Part and Accessory Expert? Answer questions, earn points and help others
