Question about Dehumidifiers
Lg dehumidifier code ch 67 - Dehumidifiers
  • 3 Answers
SOURCE: ch 01
Change the sensor assembly and all will be fine, about $30 from Appliance Factory Parts on line store, about an hour to do, all that is needed is Phillips screw driver to take unit apart.
Posted on Dec 17, 2008
heatman101
  • 43501 Answers
SOURCE: My LG LHD45EL Dehumidifier is showing a ch 01
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 10, 2010
tbreeze47
  • 3083 Answers
SOURCE: My LG dehumidifier tries to
Here is a manual for your machine, in case you don't have one:
http://homeappliance.manualsonline.com/manuals/mfg/lg/lg_dehumidifier.html
You have to join and log in to the following site, but they claim to have 2 answers:
http://www.maybenow.com/LHD65EBL-Code-CH-01-q23864244
Here's what one person said about the code on webogdery.com:
Unit keeps saying bucket full with nothing in it and it will have a CH 01 code come up on the display. NO reference to it in manual. Call customer NO service and they say to take it to a repair shop 1 1/2 hour drive away. I would not recomend this unit to anyone unless you like to keep buying new ones every year or so.
Not good news, but someone said the unit has a 5 year warranty, so you might check into that.
Another person said check the sensors:
--Shoddy craftsmanship:
1. The sensor that stops the unit when the water reservoir is removed is flimsy, often it does not detect that the reservoir is inserted back, one has to fiddle with the reservoir till the sensor finally "catches on", but then every now and then the mechanism will lock and will be unable to detect that the reservoir is full, resulting in a water spill.
It doesn't seem like anyone has figured out this code, but it has to be a sensor, or bad part, if you can just figure it out.
Good luck, hope some of this helps, and thanks for using FixYa.
Posted on Sep 13, 2010
KingDWS
  • 1606 Answers
SOURCE: Code on the dehumidifier flashes the code "CH
That is the error for a bad sensor assembly. This is about $30 from a few sources.
As an example (I have no idea how close this may be to you)
http://www.appliancefactoryparts.com/search/partinfo.php?partsid=282871
It requires a bit of work to replace. Most of that just getting everything apart. Maybe an hour or two if you do it. If you aren't handy with a screwdriver any shop can do this as well.
Posted on Sep 06, 2011
praccio
SOURCE: LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
Posted on Oct 12, 2012
Code: CH 67
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
Oct 20, 2013 | Maytag M7DH45B2A Dehumidifier
Lg dehumidifier ch 67 error
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
Jul 14, 2012 | LG LD651EBL Dehumidifier
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
Jul 07, 2012 | LG LHD65EBL Dehumidifier
Apr 16, 2012 | LG Dehumidifiers
I have a code on the screen CH 01... What do i need to do to get it to run again???
CH 01 Indicates that water collection tank is full and needs to be removed & emptied. Turn the unit OFF and unplug it, before removing the bucket.
Sep 21, 2011 | LG LHD45EL Dehumidifier
Ch 01 code
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
l;lll
Jan 08, 2011 | LG LHD45EL Dehumidifier
Gettin error code ch 01 wont run
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Nov 13, 2010 | LG LHD45EL Dehumidifier
Has ch 01 light on
I'm having the same problem. I spoke with LG today and this error code means the unit is not calculating the correct humidity percentage. I told him that I don't really care what percentage it calcs, I just want it to collect water. He told me there was no way to override this and that it will need service to operate.
Aug 08, 2009 | LG LHD45EL Dehumidifier
Ch 01
Nov 10, 2008 | LG LHD45EL Dehumidifier
Dehumidifiers Logo
73 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
