Question about Night Owl Optics Explorer NOCX3 Monocular
Got it. Tried it. worked Great! Battery cap got stuck. opened, but I think battery casing twisted and broke leads. how to open waterproof casing, to repair leads?
Chron startstop button stuck
put a spot of WD40 down the sides of the button then try pull and pushing with tweezers
Mar 27, 2015 | Swatch Irony Chrono #YOS414G Watch for Men
W to changebattery #65041g
Changing the battery on most watches is fairly straightforward and needs only the usual tiny screwdriver, insulated tweezers and a large measure of patience and good eyesight.
The main problem is usually opening the case and in the case of a quality watch that is guaranteed waterproof it really should be returned to the manufacturer for battery fitting and pressure testing. If testing isn't carried out after the case has been opened the watch realistically then becomes merely water resistant rather than waterproof.
Usually it is the back of the watch case that must be opened and in the case of ordinary non-waterproof and non-water resistant types it is a simple matter to prise the back off with a thin blade and then refit it with finger pressure.
Water-resistant watch cases that have a priseable back often need the back pressing back on with force supplied either by a purpose-made press or a large bench vice. In both cases adapters are needed to prevent damage to the case and the crystal.
A lot of watches have a back that unscrews and strictly a dedicated key, wrench or spanner is needed for this task. I have managed to overcome this problem a number of times by pressing other tools "that look as if they might do the job" into service. I cannot say what it was I used as I wandered around my workshop just trying things. I think the last time a particular circlip plier did the trick.
Simpler to take the watch and have someone else replace the battery I think.
Feb 20, 2015 | Timberland Watches
How do you open the battery compartment Bell & Howell Splash Wp7 Waterproof Camera
Slide the battery cover on the bottom of the camera to open the battery compartment. Use fresh 2xAAA bateries
Jun 12, 2014 | Bell & Howell Splash Wp7 Waterproof Camera
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
How do you get the battery case open?
hold the battery pack in you hands with the system facing away from you. Holding the unit firmly, grasp the right hand end and twist it toward you. The batteries should be placed with the two outside positive ends up and the middle one with the negative end up. Place the end back on the battery case with the top of the cap slightly toward you; push in firmly and twist it back into alignment with battery case.
Nov 24, 2010 | Rayovac Sportsman Led Headlight
Problem started with battery door
The door has an interlock on it. You probably broke the door. The door on some of these cameras can be replaced from the outside. You must make sure the interlock switch is not broken as well. The tabs on the housing of the camera can get bent or snapped off if enough force is used.
A broken door will be $75 there abouts, installed.
A broken detect switch, adds about $45 (A board).
A broken case may set you back an additional $75
Apr 16, 2010 | Canon PowerShot SX100 IS Digital Camera
Mini Maglite _ Can't open battery housing to change batteries
If there's a lanyard hole in the cap find something that will fit in that hole for leverage. If not you might have to use some vice grip pliers or two of them. There is a possibility that the batteries have leaked inside the light and has corroded the threads.
Dec 31, 2008 | MagLite Mag-Lite& Flashlight
How to replace battery?
The clip on the back can be used as a turn-knob. Twist it off, and the back comes off. I doubt that anyone has the correct battery however. This player is one of the more problem-laden mp3 players out there, so a return of the item is not uncalled for.
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
Braun Toothbrush repair?
I've just opened up and remounted my Braun toothbrush, an Oral-B model I think.
Your description corresponds.
Order for re-mounting:
Coil, rubber/soft washer, hard washer, spring, ...
The spring has no electrical use: I think it is just used to keep pressure on the washer and improve seal-ness.
The coil has 2 electrical ends, which connect to each (narrow) sides of the small PCB. One of the connections happens to touch the battery holder.
I wanted to replace the battery, but gave up as the battery seems so hard to remove: I don't see how to replace it without destroying everything.
Also, the format is larger than an AA.
Any idea?
Olivier - Belgium
Feb 28, 2008 | Braun Tassimo Espresso Machine/Coffee...
Tom tom rider
I made a video on how it open your TomTom rider.
Feb 09, 2008 | Tomtom RIDER GPS Devices
Night Owl Optics Explorer NOCX3 Monocular Logo
43 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
Ted Maxwell
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
