Question about Asko W640
Asko W600 spin cycle not working
Bought it in 1999. The high spin cycle stopped working on all settings. It however still drains the water, spins during the washing cycle but not the high speed spin on any setting. Please help.
  • 126 Answers
Check the brushes oin the motor. It's the most normal fault when this problem appears. Not a big thing to fix for a technician!
Posted on Jan 24, 2008
Will not spin out water
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Kenmore Washing Machines
Apr 24, 2012 | Kenmore Washing Machines
Whirlpool Washing Machine Leaking At top During Spin Cycle
Is it possible that the water level is too high. This can be caused by the sensor that controls the amount of water. The control knob that says small low medium large does it work if you put our small setting is the water stopped early like it is supposed to. If the water level is too high during spin cycle it is possible to run up and over the side. Let me know Ed
Nov 28, 2011 | Whirlpool Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Washer stops during spin cycle
i just relaced my door switch to my washer and it fixed my problem.my washer was doing the same thing as yours
Mar 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Washing Machines Logo
428 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
