Question about Karcher Hose Reel
How to use Karcher Detergent with pressure washer?
SOURCE: B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Posted on Nov 19, 2007
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
  • 313 Answers
SOURCE: hooking up detergent to pressure washer
detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
  • 92 Answers
SOURCE: trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Posted on Nov 19, 2008
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Karcher will not **** up detergent
onl use low pressure nozzels to pick up detergent, high pressure creats too much bck pressure
Mar 29, 2014 | Karcher Garden
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
I have filled the detergent tank of the Karcher k2.360 but when I start it up and spray the car the detergent does not come out water does but how do you get detergent to?
if you have quick release nozzles take the nozzle out and try it it will not pull soap with normal nozzles or under high pressure
Mar 25, 2012 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My 2200 Gc Karcher pressure washer oil got mixed with waer and I need to replace it. What oil should I use?
If you are talking about the oil in the pump then it should be 10W30 but must be NON DETERGENT. Remember the reservoir should only be 1/3 full
Aug 09, 2009 | Karcher K 5.85 M Electric Pressure Washer
Hooking up detergent to pressure washer
Jul 05, 2008 | Karcher 2500 PSI Pressure Washer
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Karcher Hose Reel Logo
26 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
