Question about Garden
How to take fuel tank off Stihl Ms310 chainsaw
  • 211 Answers
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
  • 22 Answers
SOURCE: My Stihl MS-180be chainsaw is leaking a small amount of gas
This saw has a fuel tank vent that could be leaking a small amount of fuel, or the fuel line coming out of the tank could be leaking. Fuel line replacement isn't complicated, you could try installing a new one. If it's the vent, odds are it's not enough to cause alarm........unless the vent line is cracked. In that event, you should replace the vent hose. Again, not a complicated repair.
Posted on Jun 16, 2009
  • 186 Answers
SOURCE: Stihl ms310 chainsaw will only run on choke
stihl chainsaw runs short time with choke when apply trigger to cut stall and is very hard to restart
Posted on Jul 19, 2009
dontbother10
  • 2220 Answers
SOURCE: stalling chainsaw stihl ms310
One more thing to try hold her on her side and loosten the fuel cap a little. A plugged vent may also cause your problem. HTH
Lou
Posted on Sep 07, 2009
SOURCE: Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Posted on Dec 31, 2009
How do I replace oil pump on stihl ms310 chainsaw
Your oil pump works with your clutch and crankshaft. Remove clutch and you will see the cover that hides the oiler. remove cover then oiler and replace with new
Oct 03, 2014 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
How to test ignition coil on a stihl ms290 chainsaw?
remove spark plug .put new one on to plug lead make good earth.turn ign. on pull over check for a good blue spark.
Jul 06, 2014 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
Stihl ms 290 wont start
Try replacing the spark plug and fuel filter to start with. Need to ensure you have fuel and spark. We have a list of things to check as techs but if it has spark fuel and compression it should run albeit poorly. If no spark check the ground circuit and if thats good replace the ignition module. If you have spark check the carburetor. It will most likely require a kit and cleaning
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 16, 2013 | Stihl Ms290 Ms310 Ms390 Air Filter &...
I need a parts diagram for an MS-310 Stihl chainsaw
You can't have one, you're not a STIHL tech, but if you tell me what part you need, I will gladly give you the part number to find.
Jul 06, 2012 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
Stalling chainsaw stihl ms310
-check and see if the air filter is clean.
-check if you have your intake selected for summer or winter, you will find that on your air intake there will be a tab insert that has a sun or snow flake insure that this is in the proper spot.
these two items list are usually the cause of what you described.
Aug 30, 2009 | Garden
You actually need the adjustment tool,looks lie a small screwdriver with a smal socket at the end of it.
Jun 02, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
