Question about Yamaha AVENTAGE RX-A820
Yamaha AVENTAGE RX-A820: Blinking light, doesn't power on??
My Yamaha RX-A1010 turns on and shuts off by itself on occasion. It also randomly switches between inputs by itself.
Your receiver may be detecting random signals from some other source. Infrared is pretty much line of sight but RF can come from anywhere.
Aug 29, 2016 | Yamaha RX-A1010 Aventage Audio video AV...
Do you have a scheme ?
How it works if you look down the drawing be a minute patient there you can read ...processing wait until you see : Get manual after this line you find by the link .
Click the preview picture to see bigger size. The preview is worse quality than the original pdf. This file is downloadable free of charge: Get Manual
(You are not logged in, only 2 downloads per day possible for you.)
YAMAHA RX A810 RX V871 SCH Service Manual free download schematics eeprom...
May 19, 2016 | Yamaha RX-A810 Aventage Audio video AV...
Need quick setup guide for the new (display unit) Yamaha Aventage RX-A550 I just purchased
which device and make
till you get the user manual
EDIt user manual link found ..next comment
turn it on
push every button on it
watch the little lights flash
May 18, 2016 | Audio Players & Recorders
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
How do I reset the protection circuitry on Yamaha RX-A820?
press and hold the 'tone control' and 'info' buttons and press power. This will release the protect. The first thing that show on the display will be the protect code to tell you why it shut down. If it turns right back off, then you most likely have a short in the amp that will need to be repaired.
Jan 25, 2015 | Yamaha Audio Players & Recorders
I can't turn on my yamaha aventage rx-a1010. How to repair it?
It might be in protect mode. Try holding the 'info' and 'tone/balance' buttons while pressing the power button. If it turns on and shuts off again, than there is something wrong internally and it will need repair
Jul 28, 2014 | Audio Players & Recorders
Yamaha rx700 will not power on or standby
Unplug the receiver and take cover off to look for fuses, and check the fuses. Is that the problem?
May 13, 2014 | Yamaha AVENTAGE RX-A700 AV receiver -...
"Internal error"
Have you had it repaired recently? Internal Error usually shows up when the digital board has been replaced and the new one has not been correctly set in the region code selection.
Dec 03, 2013 | Yamaha RX-A820 7.2-Channel Network...
Yamaha RX-A1010 died when connecting new cable
check the hdmi jack that you plugged into and make sure that none of the pins got bent. If the wrong pins touch each other or the chassis it could short out something and cause it to shut down.
Jun 24, 2013 | Yamaha RX-A1010 Aventage Audio video AV...
Yamaha AVENTAGE RX-A820 Logo
119 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
