Question about Bernina Artista 180
Singer 301 won't stitch properly, thread bunching up on underside
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Likely that it is a lower tension issue
Bottom tension is controlled by the bobbin case. First, ensure that the thread is wound tight onto the bobbin (should not be spongy when you push your fingernail into into it) Looking at the open side of the bobbin case, insert the bobbin into the bobbin case (so the thread winds off in a clockwise direction) and feed under the 'tension finger'. If you now hold the end of the thread, suspending the bobbin and case from it, the assembly should not drag any more thread out of the bobbin case. If it does, the small screw on the tension finger needs to be tightened slightly. If the assembly does not drag out any more thread, give the thread a little upwards tug. The assembly should slide down a little.If it does not slide, the tension finger is too tight - loosen it a little.
Insert a NEW needle, make sure the top thread is correctly threaded and tension is set at the 'normal' setting (as per book) ..... .... try sewing a sample. Note: using 'cheap' thread will cause all sorts of tension issues as well as fluff up your machine fast - avoid it!
Good luck
Posted on Apr 29, 2014
3 Suggested Answers
  • 106 Answers
SOURCE: Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Posted on Mar 26, 2008
  • 1116 Answers
SOURCE: my top stitch is flat, but the bobbin is bunching
What looks like a bobbin problem is sometimes the threading of the top thread.
If you threaded the machine with the presser foot down, the tension is closed and the thread cannot enter as it should.
Improper seating of the thread into the tension results in loopy stitching as the thread is not being guided at the proper tension to create a satisfactory stitch.
Try re-threading the machine with the presser foot up.
Posted on Feb 20, 2010
Thread started bunching on underside of project & tangling around bobbin. Now the needle won't pick up bobbin thread, even after changing needle 2x and re-threading upper thread. What's wrong?
Hmmm, could be several things.
Try a brand new needle. Try a different brand of thread.
Remove the top thread from the machine. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still will not pick up the bobbin thread, the machine could be out of time.
Jan 19, 2018 | Singer Sewing Machines
Skips stitches
I had/have the same problem...the gal at Joann's told me that it is USUALLY related to the needle being wrong for the fabric, an old needle, pulling as you sew, etc. Tweak everything possible, use a scrap fabric, keep resewing til machine behaves and then go to your real fabric. I always sew now with a scrap I test before doing something on the real piece. Also I was having bunching with my UNDERSIDE and assumed it was the bobbin thread. She told me the underside problems are from the top thread, not the bobbin thread..so she showed me how I was slightly threading wrong. I have a Singer Curvy and love it, but it is finicky when default settings are changed with stitch, width, length not matching the recommended settings. Good luck!
Oct 06, 2014 | Singer 3270 Mechanical Sewing Machine
Shuttle action not working, doesnt catch the down thread, bunches up thread and breaks needle.
Hi. I did not have this exact problem with my Featherweight. My machine was not stitching properly (top stitch looked so-so, but lots of thread bunching on underneath side of fabric). I took it to repair shop and learned that I was threading the needle thread on the wrong side of the metal plate which is part of the take-up arm (I do not think that the threading instructions make this distinction). After the repairman pointed out the problem & threaded the machine, it made a proper stitch.
My suggestion for this issue: check the bobbin threading. My bobbin has to be inserted so that it turns counterclockwise in order to catch the down thread.
May 27, 2014 | Singer Featherweight II 117
Singer 8734 :my thread is bunching up under the fabric. How do I adjust the bobbin?
If the thread is bunching up, it sounds to me like the stitch isn't being formed properly. Nothing to do with the bobbin, more a case of timing.
The spike, or whatever it is on your machine, which is under the needle, must pass through the loop in the thread from the needle at exactly the right time.
When the needle reaches it's lowest point, as it starts to go upwards again,a loop is formed in the thread,next to the needle eye. This loop is what the spike must pass through in order to make the stitch.
May 19, 2014 | Singer Sewing Machines
The bobbin thread is bunching
if by bunching you mean thread looping on underside, then there is insufficient needle tension for thread control lever to set the stitch. check tensioner is working properly
Feb 23, 2014 | Brother Sewing Machines
Thread topside of Singer #5438 serial #C82656250
singer has a free pdf instruction manual for download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 5438) & click search
Feb 02, 2012 | Singer Sewing Machines
I have a Curvy 8770 and continue to have problems with my underside thread bunching. I have rewound the bobbin, cleaned the machine and continue to have these issues. What am I doing wrong.Everytime I...
Be sure to change the needle often.
Sounds like bird nesting.
ALWAYS RAISE the presser foot and rethread from the beginning.
Jan 24, 2018 | Singer Curvy 8770 Electronic Sewing...
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Sewing Machines Logo
50 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
