My rth2410b1001/a stuck on schedule how do reset
My thermostat says "hold" why?
Hold means you are always controlling the set temperature. You want a hold if you do not wish to have a set schedule. Not sure of your tstat but likely if you press run you will return to your schedule. Or by pressing hold again will return to schedule. IF THIS CHANGED BECAUSE OF A LOSS OF POWER you will likely have to edit your schedule.
Aug 07, 2017 | Heating & Cooling
Scheduler does not work
first you check your memory card.because i think your memory card is infected thru virus.so you scan your memory card and after that plug in your mobile phone.
Jul 30, 2012 | Nokia E63 Cell Phone
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Apr 02, 2010 | Emerson SmartSet CKS1850 Clock Radio
G37 "replace oil filter" light. How to reset? After my initial scheduled maintenance, the oil filter light was not reset.
go to status, maitenance and then set the next oil change schedule to 37500 mile from what you have in the Dem.
Oct 06, 2009 | 2009 Infiniti G37
Honeywell air conditioner wont turn on. says following schedule
take the front face plate off wall it may have a reset button behind it
May 18, 2009 | Honeywell Electronic Programmable...
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Maintainence light
maintnaince schedule light there a few thing to do like oxygen sensor but for my customer if the car gose good i tell then not to worry and i reset the light to reset hold the black nobe in the dash where speedometer is put key on hold it for more then 10 second it will flash and come off good luck pierre
Jan 31, 2009 | 1997 Honda Civic
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
