Question about Icom IC-7600 HF/6 Transceiver
This is a new 7600 only transmitted with it for about one hour and now I can only get about 30 watts output, my 20 meter antenna has a 1.5 swr all cables are tight. Any help would be greatfull
    Sergeant:
  • 435 Answers
I'd contact Icom, since its under warranty get it fixed
Posted on Feb 11, 2015
2 Suggested Answers
SOURCE: icom ic 7600 rf issue
it is just because your cable is loose, try it after tightning it up
Posted on Jun 05, 2012
CB warning antenna on a cobra 29 lx camo
You may have blown out the output transistor in the CB. Can you still calibrate the swr meter? The K 30 isn't really a very good antenna. The Lil Will isn't either. I'd try a K-40 or a better model Wilson antenna.
May 08, 2016 | Cobra Radio Communications
I hav a 29ltd classic cobra cb radio i had it tweaked first did not notice a diference in transmission but reception is still normal then i installed a rxf 75 amp and my reception decreased and everyone...
Receive amps on a Linear's can cause this issue---the key question is what is the dead key wattage in the radio adjusted to?
You hook an amp up--jumper cable length between amp and radio is critical---the power output of radio is critical--put 4 watts into a 75 watt amp and it will be over driven-- The proper way here is with radio and amp hooked to a big dummy load adjust the radio wattage output so the radio keys up the amp and gives maximum forward swing on a watt meter. (in some cases as little as 1 watt output from radio)
Some people call this matching the radio to the amp---The antenna system then becomes involved--further adjustment of the radio with the antenna system connected will be needed (power output) for the amp to work well.
If just a 29 LTD lowest Swr should be on channel 20.
Note: also important to check the swr with the Amp on as if power is being reflected back at radio when amp is on more needs to be done.
SD TECH
Apr 21, 2012 | Cobra 29 LTD CB Radio
It says cb atanna warning when i key the mic. i have a new cable and new atannas as of 20 min ago. what is the problem
The problem is you need to tune the antenna.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Aug 10, 2011 | Cobra Radio Communications
The light for high swr keeps coming on. replaced antenna and coaxle. how do i go about lowering the swr. is there a nob or switch for this. thank you
You cannot lower the SWR via the radio. it has to do with the antenna. The length of the antenna is essential to transmitting properly. It must match the transmitting frequency.
To check SWR tune to ch 20. Flip the meter switch to CAL. Key the radio without talking into the radio. Turn the CAL knob up until the meter needle is at the CAL mark. Unkey the mic. Flip the meter switch to SWR. key the radio again, and the meter will show your SWR. We already know it is high because you are getting antenna warning, but we will have a base line now to work on.
What you did was calibrate the meter for that channel. that is necessary to check the SWR. So you must calibrate for each channel you check.
You should at least be under 2 swr. Ideal is 1.5 or under. the lower the better.
If your SWR is high, your antenna is either too long or too short. To find out here is what you do:
Check the SWR on ch 1 and ch 40 calibrating for each channel. Compare the difference of the SWR between 1 and 40. If the SWR is higher on 40 then 1, your antenna is too long. If your SWR is higher on 1 then 40 your antenna is too short. All CB antennas have a way to adjust the length.
If its a mag mount, its usually a set screw you loosen to raise or lower the whip. Fiberglass antenna's usually have something under the cap at the tip to adjust. It will either be like the mag mount, with a set screw and a small rod to raise or lower it, or a screw, that you screw in or out to make it longer or shorter.
make small adjustments. 1/8th or a 1/4 of an inch at a time. Each time you make a change, take an SWR reading on 1 and 40 again and compare the difference. The difference should be getting less. Do this until there is very little or no difference between 1 and 40.
Then you go back to 20, because it is the center channel and check the SWR there. It should now be low. If you did a good job it will be under 1.5 and you are good to go.
Aug 07, 2011 | Galaxy Radios DX-93T Base CB Radio
DX 2547 Only transmitting at 1 watt and swinging backwards on the power on high side from 4 watts to 1 watt.
Check the SWR reading on your antenna. If you have the wrong adjustment here, it is like having the wrong antenna, or none at all. You will need a SWR Meter, and somebody who knows what he/she is doing to help you.
Mar 25, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
DX 2517 keys up, light turns red, audio shows on meter, and through talkback, but no signal at all. whats goin on?
You need an SWR-PWR meter ($20) to run between radio and antenna to see 1) if you are transmitting and 2) if the is a problem with the antenna (SWR). There may be a bad antenna connection or it is grounded out. If the SWR and antenna check out you may have damaged your finals in the radio.
Feb 25, 2011 | Radio Communications
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
When I key the mic the radio blinks out and then comes back on
This can be due to one of several problems. Insufficient sized wires to the power source or a high SWR (standing wave ratio) between transmitter and antenna. The first is probably not a problem unless connected to an RF amplifier to boost output wattage. A high SWR however, is a more likely culprit. SWR is a ratio of power out of the transmitter to power that is reflected back from the antenna. Ideal theoretical ratio or "match" is 1:1. Real life is more like 1.1:1 (one point one to one). Most transmitters are perfectly happy with a match (or mismatch as the case may be) of 1.5:1 or even 2:1. Beyond this is asking for trouble. A mismatched antenna system can cause the failure of the output final transistors.
Matching or lowering the SWR of a radio to an antenna system requires that an SWR meter be installed between the antenna coax or cable and the transmitter's antenna connection point. There are two types of meters - dual needle and single needle. The dual type is more expensive, but easier to work. The meter must be capable of working on the frequency it is to used on. This means if it is marked as a 400 - 512 Mhz or UHF type, it will not be accurate on 27 Mhz or HF.
Once the meter has been installed, transmit at half power (or at least the amount needed by the meter) on the highest frequency and take readings. Do the same at the lowest and a middle frequency and record findings. Physically adjust the length of the antenna whip - by no more than 1/4" inch (for 27MHz CB frequencies) and check again. After a few tries, you should begin to see how shortening or lengthening the whip changes the SWR of the system. Once set correctly, the middle frequency will have the lowest SWR value while the lowest and highest frequencies will have equal higher SWR values. It would go something like this: Ch1 = 1.6:1 Ch 20 = 1.2:1 Ch40= 1.6:1 Of course, if Ch1 = 1.7:1 and Ch 40 = 1.6:1 that would be fine, too.
Double check everything once more at full power, so that you know the transmitter won't be damaged under full power conditions. Make any last adjustments and lock everything in place.
Aug 21, 2009 | Radio Communications
Matching c b antenna with c b radio
here is some information that will help you test SWR with an inline watt meter. To get proper results you need to use an inline watt meter. Here is a really good site you can go to for help www.cbradiotalk.com
Equipment needed: SWR meter, short jumper coax 3 foot.
midland.jpgProcedure: The SWR meter needs to be placed in line between the antenna and the CB. Connect the antenna (normally connected to the back of the CB ) to the connector marked "Antenna" or "Ant" on your SWR Meter. Connect one end of the short jumper coax to the "transmit" or "Xmit" on the SWR meter. Connect the other end of your jumper coax to the CB.
Assuming you have a standard SWR meter the switches should read as follows: REF or SWR, FWD, and there should be a slide switch marked "set" or "Adjust". If different consult your meter's owners manual.
With the radio on the lowest channel (1 on CB) and the SWR meters switch in the Forward (FWD) position, depress the transmit switch (key up) located on the microphone. While holding the unit in this transmit mode, adjust the meter needle to the set position using the Set or Adjust knob on the meter. As soon as the needle is in alignment with the corresponding mark on the meter face, flip the switch to the Reference (REF) position. The meter is now showing your SWR on channel one. Note the value and quickly release the microphone switch. Record this reading.
Repeat the previous step on channels 19 and 40.
How to read your results: If SWR on channels 1, 19 & 40 is below 2.0, your radio can be operated safely.
If SWR on all channels is above 2.0 but not in the "red zone" (normally over 3.0), you may be experiencing coaxial cable reaction (bad quality, wrong length, etc.), insufficient ground plane, or have an ungrounded antenna mount.
If SWR is in the "red zone" on all channels, you probably have an electrical short in your coax connectors, or your mounting stud was installed incorrectly and is shorted. Do not operate your radio until the problem is found, serious damage can occur to your radio.
If SWR on the lowest channel is higher than it is on the highest channel, your antenna system appears to be electrically short. Your antenna length may need to be increased.
If the SWR on channel 40 is greater than that on channel 1, your antenna is considered to be "LONG" and reduction of physical height and/or conductor length will correct this situation.
Aug 01, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Icom IC-7600 HF/6 Transceiver Logo
110 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
