Question about Whirlpool Washing Machines
Clean pump WSF1073DD front loader - Whirlpool Washing Machines
4 Suggested Answers
  • 949 Answers
SOURCE: Where is the pump/filter located on my Kenmore Front Loader Washe
It is just behind the lower panel. Remove the 3 screws from the lower panel (the panel just below the door), the screws are on the lip on the bottom of the panel facing the front of the machine. Pull down and toward you to get the panel off. The filter and clean out are in the center. Unscrew the cap to remove and clean out, but have lots of towels ready, there will be water coming out.
Posted on Apr 21, 2010
heatman101
  • 43501 Answers
SOURCE: My Whirlpool front loader washer
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 22, 2010
  • 113 Answers
SOURCE: Whirlpool WFS1273AW Front loader The clean
Remove bottom panel. You should see a trap on the pump. Rotate cover ccw. Have pan ready to catch some water, or some towels.
Posted on Sep 28, 2010
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
Front loader has stopped mid wash and red light has come on saying clean my pump. How do I do this?
Not knowing which model you have makes it a bit difficult. Most front loaders have a little trap door down on the front panel somewhere. Behind this door is access to the pump filter. Usually, it just unscrews, and you pull it out. If your machine is full of water, expect a mess. remove any buildup of fluff, foreign objects etc. If your machine has no trap or access. Unplug the machine and drag it away from the wall. Lean the machine back against the wall to gain access underneath. You should be able to see a large hose from the tub to the front ( or side) of the pump. They are usually held on by a spring clip. Slide the clip back or unscrew the clip to enable you to pull the hose off the pump. Clean out any foreign objects you find. As before, if the machine is full of water, expect a mess. Front loader drain hoses usually exit out the top of the machine so lying the end of the drain hose on the ground wont drain the water.
Jul 26, 2011 | Whirlpool Washing Machines
Washer won't drain. Pretty sure it's clogged but not sure how to check for this.
Hi, You don't mention whether this is a top loader or front loader. On the top loader you need to get to the drain pump. Front of washer may come off or the lid comes off and then the front. Some of them had clips under the console. Once you are at the pump, take a shop vac and empty the water. Both hoses inlet and outlet will have to be removed and cleaned. BEFORE YOU DO ANYTHING ON THIS, UNPLUG THE MACHINE!!! If its a front loader the kickplate has to come off or the whole front, and same procedure as above. Hope this helps.
Jan 18, 2011 | Washing Machines
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Apr 20, 2010 | Kenmore HE2 Plus Front Load Washer
How do you clean pump on front loader washer? red light said to clean
Theres a tutorial www.shop.washermd.com to clean a pump. Dave
Jan 13, 2009 | GE WSXH208A Front Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal De
