Question about Garden
John Deere troubleshooting lt190 mower start but will not run at allspeed of engine replace fuel pump and carbrator and spark plugs tolk off the cover we the push rods are and one of the top ones not in place
  • 81 Answers
SOURCE: What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Posted on Apr 13, 2010
wireguy212
  • 1627 Answers
SOURCE: john deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Posted on Apr 25, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Posted on Aug 18, 2010
  • 6468 Answers
SOURCE: Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Posted on Apr 30, 2012
Engine doesn't start and run...just turns over.
take the spark plug out and crank the engine over for 30 seconds to blow out any gas that may be in there. get another or a new spark plug and put it in and try to start it. maybe check compression to see if the valves are working properly. if you have spark and fuel and compression it should.
Sep 20, 2016 | John Deere Riding Lawn Mower. EZtrak Z225...
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
2005 John Deere. Why doesn't it run?
put a new spark plug in it. i just fixed a john Deere i worked on for hours. the only thing i didn't do was replace the spark plug. after i put a new plug in it it ran like new.
Mar 12, 2016 | John Deere Garden
Looking for a download for electrical wiring diagram for a John Deere LT190
LT190 - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM152795.../OMM152795_H46.html
Disconnect spark plug wire(s) or battery negative (-) cable to prevent engine from starting accidentally. ยท Always wear gloves when handling mower blades or ...
Oct 15, 2015 | John Deere Garden
Have john deere lt190 after a few minutes running it shuts down. New fuel filter cleaned carburetor and gas tank changed oil. What else could it be??? Stumped
run it till it stops, have a spark plug ready to check for spark, if there is no spark, chances are the coil is bad
Sep 04, 2015 | John Deere Garden
John deere lt190
If fuel is getting into the oil, I would say the needle and seat or float in carb is not stopping fuel flow. I would check carb again and adjust float level. Change or install an inline fuel filter too. Surging is almost always carb related. If problem persists after checking carb again, check governor springs. If they have been bent at all after removing carb, they can be bad. If you replace new governor springs and surging still exists, try doing a static setting on carb/governor. If your unit has an oil/centrifugal governor, move governor arm in the direction that opens throttle valve in carb all the way, hold in place, loosen nut on governor arm and grab small tang that goes inside engine and turn in the same direction you moved governor arm, rotate this until it stops, hold in place and tighten nut on bottom of governor arm. This is called a static/factory setting. Make sure throttle cable is in high position when doing this. Let me know if you have any questions. Good luck!
Oct 22, 2013 | Garden
Scotts by john deere riding mower - 220 hours, 17.5 HP, 42" cut, Briggs & stratton engine -- New Strarter, new battery, good fuel... will turn over but engine will slow down then stop, will not...
Very high likelihood you have fuel line problems. Disconnect primary fuel line from bottom of fuel filter and blow compressed air back up the fuel line to the gas tank. This will clear the line of any trash. Reconnect fuel line to filter. Then remove spark plug and spray a couple of sprays of WD-40 into the cylinder.. Re-install spark plug and then restart. WD-4- will act as a starter fuel and will start the engine for enough rounds to get fuel pump to working to normal run.. Good luck.
May 15, 2011 | Briggs & Stratton Garden
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Hope this helps.
Apr 13, 2010 | Garden
John deere 445 with 22 hp kawasoki engine wont run take 1 plug out it runs dont mater what side stick finger in plug hole engine shuts off ,but wont start with both plugs in
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Sep 03, 2009 | John Deere Garden
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
