Question about Dell (11588) Internal 8x CD-ROM Drive
C400. DVD - ok! CD- cannot see!!
I have a problem with my CD/DVD ROM. DVD disks work OK, but it cannot see CD disks. I tried different CD disks. Once a DELL installation disk worked, but others - no. And later even this DELL disk did not work again.. Previouselly my CD/DVD ROM worked OK. Windows was reinstalled successfully when hard drive corrupted and was replaced under DELL warranty. Please help, if anyone can! I cannot install software because of this!!
  • Ebrantley Dec 07, 2007
    All of a sudden my C4-- external CD ROM also cannot see any of my disks. I wonder what brand of external will replace it?
    EdB
    President:
  • 216 Answers
Use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Posted on Dec 30, 2009
    Problem Solver:
  • 19 Answers
you can try the steps below to fix this issue.
Edit the registry:-
1. Click Start, and click Run.
2. Type regedit in the Open box, and click OK.
3. In Registry Editor, click the plus (+) sign next to each folder name to expand the following registry path:
4. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the right pane, right-click Upper Filters, and click Delete.
7. Click yes when prompted to delete the registry value.
8. In the right pane, right-click Lower Filters, and click Delete.
9. Click yes again.
10.Close the window and restart the computer
Please do not forget to rate the solution.
Regards,
Musheer.
Posted on Jun 15, 2009
SOURCE:
Dvd rom not working propetly
Please try to insert another disk for testing.
If nothing works then try to check with another DVD rom for testing.
If the other DVD rom not working then this is registry of windows problem
If other DVD rom works then your original DVD rom is faulty.
Mar 05, 2013 | Acer Aspire 1640Z Notebook
Cd/dvd rom cd not working
I would first suggest to clean the drive with a cleaning disc, can be purchased at any electronics store, it's a cd with microfober brushes on it that cleans the drive as this disc spins.
Sep 24, 2007 | Dell Latitude C400 Notebook
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
What did I do wrong? I copied doc files to a CD.
Is it a dvd-rom, dvd-rw, cd-rom, cd-rw?
What is the cd/dvd disk drive you are using?
(A dvd-rom, dvd-rw, cd-rom, cd-rw?)
This may be the problem.
Aug 22, 2009 | Compaq Computers & Internet
Optiarc dvd rw 7530B will read CD,CD-rom but No DVD, DVD-rom
it can read cd but not dvd isnt it. this cause your dvd rom faulty pls try borrow from somebody and replace it first see how ok
Jun 07, 2009 | Computers & Internet
Extrenal cd rom will not boot
Go into the setup menu on boot (before the windows screen appears) by pressing F2 or F10.
Go to the Boot Options and check that the CD-ROM/USB Device boots before the hard disk drive. Save and Exit.
Mar 05, 2009 | Dell Latitude C400 LCD DIsplay Bezel -...
O.K. now that I installed my DVD/CD Rom it will
i think this is a common problem we encounter when DVD rom lens is becoming faulty. it can only read cd but not DVD then after some time wont read any disk at all. if your drive still has store warranty it would be best to claim the warranty. i tried fixing this kinda problem but it cost me almost the price of a new 1 LOL.
Feb 18, 2009 | Compaq Presario 700 470024-192 Notebook
Cant install xp to dell c400 with external cd-rom
This is how I did it, you may or may not have the ability. A basic knowledge of Dos is necessary 1) I used another laptop but you could use an adapter to use the hard drive in a regular computer. 2)boot with a windows 98 boot disk, fdisk it to a fat32 partition, make the hard drive a system boot disk (format /s c:) 3) copy the i386 folder and all its contents from a full or full oem (not branded) disk to the laptop drive, also copy smartdrv and highmem.sys from the floppy (speeds thing up dramatically) and create a config.sys file with device=highmem.sys 4)physically install the hard drive back into the C400, boot to dos run smartdrv.exe, then go to the i386 folder and type winnt.exe (enter) wooo should work. MusslaChooda Pakichooda Nathuram Godse
Oct 22, 2008 | Dell Latitude C400 Notebook
DVD-CD ROM not working
change the cable on it ide cable dust out case inside relly well get all dust out clean cool ok change ide cable if not buy new dvd rw drive
Jan 16, 2008 | Compaq Presario 5000 PC Desktop
CD/DVD rom. CD part - does not work
Inside your DVD rom is two heads I believe they are diamond both do the same things which is to read them. The CD head is poked (Broken). Try cleaning it with the proper solution. If its no go then the latter I am afraid stands!.
Open Questions:
See all Dell (11588) Internal 8x CD-ROM Drive Questions
Computers & Internet Logo
55 people viewed this question
Ekse
Clive
Clive
