Question about JVC HD-61FN97 61" Television
JVC Model hd-61fn97. Symptom: After long warm-up, three wide vertical bands, about 14-inches wide, appear on the screen. The bands are not solid but made up of of 1/4-inch dark vertical stripes,like the stripes in a pin-stripe suit. There is no distortion 0f the picture, and the stripes are not black enough to totally obscure the picture behind them.
  • 579 Answers
SOURCE: JVC AV-48WP30 has vertical lines every inch or so...
This may not be the problem but its worth a try:
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
ctf1800
  • 4402 Answers
SOURCE: JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Posted on Jan 31, 2008
  • 3422 Answers
SOURCE: Vertical Black Line
HI,
First thing to do is the reset and the whacking test. I give this a 50/50 chance of clearing it up.
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If these two procedures do nothing then:
The manual always knows the best.Go through the manual carefully and u will find the solution to ur problem..
Goodluck and Kind Regards
Please Don't forget to rate me as fixya..
Posted on Feb 02, 2008
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Posted on May 11, 2008
SOURCE: JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
Posted on Oct 14, 2008
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
I have a 2 inch black band which appears intermittently dwon the full height of a 22inch JVC lcd television can anyone explain it for me? thanks
If it is black vertical band from the top all the way down to the bottom of the screen, your LCD panel is going bad and you will see more bands and it will get worst.
Nov 04, 2009 | JVC LT-23S2 23 in. LCD Television
I need a new screen for my tv it got broke. Its a jvc HD-61FN97. I need to get a price also.
you may have to contact JVC tech & customer service , heres a link:
http://support.jvc.com/consumer/support/index.jsp ,good luck , please rate ME , thanks AJ
Oct 26, 2009 | JVC HD-61FN97 61" Television
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Oct 23, 2008 | IBM ThinkPad R50e Notebook
Replacement of front plastic screen
well, unless you are really really lucky and could find the same model at the local tip, you will need to ot\rder and replace the part through a repair center or parts center of sorts, quite costly
Aug 05, 2008 | JVC HD-61FN97 61" Television
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
JVC HD-61FN97 61" Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
