Question about GE WJSR1070A Top Load Washer
Washing machine overflows
GE top loader fills up and drains fine initially, but overflows when it fills up the second time for the rinse cycle.
  • Anonymous Mar 15, 2014
    the rinse and fill cycle will not come on when required
  • 447 Answers
Very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
GE Washer overflows
washing machines of any make or shape have a level sensor, this normally consists of a thin pipe from the lower end of the machine (where there is water) normally enters the bottom of the outer drum casing, this thin rubber or thin plastic pipe goes up to the top of the machine just inside the casing, it leads into a "pressure switch" a circular disc object about 50 cms in diameter on average, also this has about 4 to 6 wires on it, this thin pipe becomes blocked not allowing air to be forced up the tube into the switch, not switching the machine water flow off when it gets to the correct level empty the machine, drain off the water, unplug the power supply, and clear out this pipe, normally its congealed old soap powder, place pipe back as it was, checking for any leak holes in it, if damaged, replace it with new, run machine again to test long winded but i hope i have explained it thoroughly
Sep 24, 2007 | GE WJSR1070A Top Load Washer
GE WJSR1070A Top Load Washer Logo
190 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
