Question about Samsung Refrigerators
The "wide open cool select pantry" drawer will not open on our Samsung refrigerator model code RFG297HDRS/XAA
  • 531 Answers
SOURCE: Food in Chef's Pantry drawer freezes, even on warmest setting
check the cold control or the door is not closing proper
Posted on Apr 01, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
quatlew
  • 139 Answers
SOURCE: I have a Maytag Side by side MSD2356AEW unit.
Do a manual defrost overnight by unplugging and leaving the doors open the opening should not be frozen. Alot of humidity or constantly opening the door sometimes causes the frostup.
Posted on Mar 13, 2010
Testimonial: "Thanks very much for your help. It worked!"
dr appliance
  • 266 Answers
SOURCE: Our Samsung RF265AB (bottom freezer) is leaking
have a water tank or line leak for water dispensor
Posted on Jan 27, 2011
ginko
  • 19396 Answers
SOURCE: I have a Samsung RFG297AABP
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
Posted on Apr 15, 2011
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Can't get rf266abpn cool select pantry drawer back in
There may be guide rails on the underside of the shelf above.
Apr 25, 2016 | Refrigerators
Samsung refrigerator rfg297aarf cannot put cool select pantry drawer back?
I don't remember exactly how that one works but try these two options...
1) tip the front of the drawer up more than 45 degrees and connect the rear to the tracks, then lower the front until the drawer catches on the rails - it will push in and slide out correctly.
2) look under the shelf where the drawer attaches, you may have to get down on your knees and really look in. Pull all moving clips that are in the drawer tracks forward (they may have been moved back while cleaning). Then connect the drawer to the slider clips (it should be obvious how they clip in if you have the slider clips).
Hope one of those was right for your unit.
Cheers
Jun 06, 2015 | Samsung Refrigerators
Cool Select Pantry, to relocate per manual instructions, doesn't slide all the way in.
Cool select Pantry
To remove the pantry - Pull the pantry out to full extension. Tilt up the front side of pantry and pull straight out.
To relocate the pantry - Push the rails to the back of the Refrigerator. Place the drawer onto the rails and slide the pantry back until it is in place.
before install they ask to push the rails to the back of the refrigerator
should be no problem
Jul 29, 2014 | Samsung RFG297AARS Bottom Freezer French...
My RF263AEWP Samsung is 3 weeks old. The pantry cool drawer sticks as I pull it out and sticks as I push it in. The lid does not close completely on one side.
Mine does the same thing. The repair man brought a new drawer and it does the same thing. Look underneath and you will probably see that the wheels don't fit correctly on the tracks. Samsung is saying this is how it's designed. :(
Sep 20, 2010 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
151 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
