Question about Fitbit Weight Tracker
Fitbit wireless dongle unplugged - Fitbit Weight Tracker
How do I sync my fitbit ulta
Bring your charged fitbit near to the plugged-in dongle or base station. You may need to press your fitbit button or tap it to wake it up. Then, Click the Fitbit Connect icon. Finally, Click Open Main Menu, and then click Sync Now. You may be asked to sign in, after which your fitbit should sync with your account.
If these steps do not work then please review the link below for additional trouble shooting tips.
Why isn my Ultra tracker syncing to my computer
Aug 03, 2016 | Exercise & Fitness
Need to reset time on my fitbit
you have to resync it with the dongle plugged into a computer.
was it a fitbit zip ? if yes then
you will have to take battery out and then put back in. for about two minutes you will be able to hook it up to a pc via the dongle and fit bit software .As it goes into pairing mode . for about two minutes from having battery inserted.
Jul 28, 2016 | Exercise & Fitness
How does fitbit work?
you wear it on your wrist after you charge it up via the usb charger.
You download fitbit app on your phone and then add fit bit to phone .
I am not sure how it works I am guessing it has a motion detector in it and each step causes a vibration it detects.
It must have some sort of a pulse sensor as it also knows when you are a sleep .
you need to set up an account using an email address with fitbit via the app.
there is also a windows app but you need the fit bit dongle that comes in the box it came with plugged into the usb port of p.c.
even thoug pc has bluetooth it does not seem to work with the p.c application unless the dongle is used with it.
Dec 31, 2015 | Fitbit Flex Wireless Activity & Sleep...
Fitbit charge HR users manual
Fitbit has the manuals for most of their products on their support site. For the Charge HR, see http://help.fitbit.com/?p=charge_hr . The link to the manual is the first link in the line "Charge HR Resources" near the top of the web page. The direct link is https://staticcs.fitbit.com/content/assets/help/manuals/manual_charge_hr_en_US.pdf .
I hope this helps.
Jun 02, 2015 | Exercise & Fitness
Why does my fitbit always shows information from two months ago instead of present dey
Sounds like you need to re-sinc the fitbit to the computer via dongle, or via smartphone.
Feb 28, 2015 | Fitbit Flex Wireless Activity & Sleep...
Need help downloading a fitbit to my hp computer
  1. Go tohttp://www.fitbit.com/setup/and click theDownload Herebutton to download Fitbit Connect for your Force, Flex, One, or Zip tracker. If you have an Ultra, you should instead followthese steps.
  2. Once the download has completed, open the file and begin to follow the onscreen instructions.
    If you are on a Mac, open the dmg file. If it doesn't appear on your desktop, search for "Fitbit Connect" in Spotlight.
    If you are on a PC, run the .exe file from your download location. If it doesn't appear on your desktop, search for "Fitbit Connect" in the Start menu.
  3. Once the installation is complete, you will be presented with the Fitbit Connect Main Menu. SelectSet Up A New Fitbit Device.
  4. Account Setup:
    • SelectNew to Fitbitif you don't already have a Fitbit.com account.
    • SelectExisting Userto log in using your existing Fitbit.com account.
    • ou will be asked for a few details about yourself. This information improves the accuracy of your caloric burn and distance data. You can later adjust yourprivacy settingsto control which details are shared with others.
    • After filling out your personal information, you'll be asked which device you're setting up. Select the appropriate tracker to continue.
    • Plug the wireless USB sync dongle into your computer (this is the smaller USB device--not the charging cable), and bring your tracker near to it to begin pairing.
    • Tracker Pairing:
      • Force, One, or Zip: You will see a pairing number that appears on your tracker's display once your device has been located; enter this number on your computer.
      • Flex: Follow the onscreen instructions and rapidly tap the device when instructed, then confirm its vibration.
    • After clickingNext, your tracker will connect to your Fitbit.com account. This can take up to a minute.
    • Once your tracker has connected to Fitbit.com, you may be prompted to enter a greeting (depending on which tracker you have). This can be your name or any 8-character combination of letters or numbers.
    • When your tracker is linked with your Fitbit account, Fitbit Connect will notify you and present some basic instructions on using your device.
    • You can now log into your account dashboard to view your synced data.
      You will not need to repeat these steps once they have completed--you can simply login tohttp://fitbit.comto access your dashboard.Or Still having Problem Then follow Us For
      HP Support
Apr 24, 2014 | HP Office Equipment & Supplies
I installed the lg dongle to my LED usb port and followed al the steps. When I select USB 1 where my dongle is located, it tells me no storage units available. Why is that?
You need to go into the wireless settings not the Input source. Go to Menu and then Connection and continue from there. You can also unplug your dongle and plug it back in while the TV is on and it will auto detect the dongle and ask you if you would like to set it up now. Good luck
Sep 08, 2010 | LG ANWF100 Wireless dongle
Fitbit Weight Tracker Logo
55 people viewed this question
Top Fitbit Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Fitbit Facebook App Expert? Answer questions, earn points and help others
