RCA RT2781H Surround Sound keeps shutting off on me, I checked wiring, checked to make sure sleep mode was shut off, can't figure out what is wrong with it, just bought it and set it up and about to take it back to store already. :( Any help is appreciated.
Quickie
  • 54 Answers
SOURCE: sleep mode
usually, to get a PC out of sleep mode, you either press the ESC key, press the power button a bit quickly, or press the sleep key agian. It really depends on the system. Try any of those to see if it helps.
-Chad
Posted on Dec 12, 2007
SOURCE: RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Posted on Dec 28, 2008
SOURCE: no sound from back surround speakers
I resolved the problem by going in the dec mode (page 49 of manuel) and changing the setting to Pro Logic. That did the trick. Good Luck all.
Posted on Jan 26, 2009
Joed911
  • 4338 Answers
SOURCE: PowerBook g4 won't wake from
Found this, it may help you solve your issue. Power issues on Mac G4 The PMU is a microcontroller chip that controls power functions for the computer. The PMU is a computer within a computer, as it has its own memory, software, firmware, input/output, a CPU, and more. Its function is to:
§ Tell the computer to turn on, turn off, sleep, wake, idle, etc.
§ Manage system resets from various commands.
§ Maintain parameter RAM (PRAM).
§ Manage the real-time clock.
Over time, the settings in the Power Manager may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, or not seeing devices plugged into the USB and FireWire ports, among others.
Resetting the PMU is not intended for resolution of a stall or situation in which the computer is unresponsive. A PMU reset should not be necessary except as a last resort in cases where a hardware failure of the power management system is suspected. Performing a PMU reset returns the computer hardware, including NVRAM, to default settings and forces the computer to shut down.
http://support.apple.com/kb/HT1939
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 16, 2009
SOURCE: gateway notebook m1624-shuts off randomly by itself
Check if your laptop is hot on the bottom left corner. If it is hot that means that the cpu thermal past is dry out. I have to sent in to gateway 5 times for the same shut down problem while it was still in warranty. The gateway m-1624 has a poor cooling unit. I hope that help you.
Posted on Jul 24, 2009
How do i reset?????????
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 27, 2015 | RCA RT2781H 5.1 Home Theater System - 1000...
Rca rt2781h
install new window properly and the install the anti virus eset node 32...ur computer works nicely
Jun 17, 2014 | Audio Players & Recorders
Rca rt2781h loosing sound
Hi. replace the hdmi cable with a new one..
Aug 04, 2013 | Audio Players & Recorders
Amp shutting down when volume gets too high
Easy! You either have a surround speaker wired backwards or there is a break in the wire leading to a surround speaker that is allowing the +&- to arc together. your amp shutsvoff as a protection to keep the arc from reaching the mother board. replace your wires man!!
Nov 29, 2012 | Pioneer Audio Players & Recorders
How do you hook up rca surround sound system to rca tv for sound
I can not figure out how to wire my 46" lcd rca tv to my rca surround sound.
May 21, 2010 | RCA L32HD31 32 in. LCD HDTV
Surround sound shuts off like the sleep timer is on
power amp problem are you familier with electronics?
then we can do more.
shall we?????
Jan 03, 2009 | Samsung HT-WX70 Theater System
My Polaroid 42 Inch LCD Keeps shutting off.
This might sound a little crazy but, i had the same problem with my rca 50 inch, and he changed the bulb. which are pretty $$$$$125.00 at my tv repair person cost. the real cast was $219.00.Hope this helps you
Dec 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung 5-Disc 1200-Watt Home Theater Surround Sound System My Home Theatre System is keeps shutting down by its self. before it shuts down the screen says protection mode and then shuts down. i have...
If the unit shuts down almost immediately without sound, you have an electronic failure of the audio amplifier.
However if you must play the unit up above quiet background levels, you likely have a shorted speaker wire. With home theater systems, you have the luxury of trying different surround modes and speaker level settings. It's not unusual, for example, to have a loose wire strand going to the center speaker. In stereo, the system works fine. As soon as you switch to a surround mode, the amplifier senses the short and shuts down to protect itself.
Check those wires really close - I bet you'll find it there.
May 15, 2008 | Audio Players & Recorders
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
828 people viewed this question
 Grubhead
Grubhead
