Question about RCA Audio Players & Recorders
My RCA rt2781h surround system keeps shutting off after 1/2 hour or so and it's upsetting me, checked all the connections, everything is good,thought maybe the sleep timer was set but it's not. Any help would be appreciated.
djnick989
  • 1067 Answers
SOURCE: Television surround sound problem
well u have to use tv rca out to a input on this system ok then select input 1 aux in ect on sound system ok
Posted on Feb 02, 2008
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
nuwan chinth
  • 111 Answers
SOURCE: surround sound shuts off like the sleep timer is on
power amp problem are you familier with electronics?
then we can do more.
shall we?????
Posted on Jan 08, 2009
  • 16 Answers
SOURCE: resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Posted on Jan 12, 2009
thesuperdude
  • 97 Answers
SOURCE: Sleep mode
You will need to exit the application and exit to dos. From the d: prompt, type cfg24 and that will give you the configuration menus. From there you will find the sleep mode settings.
Posted on Mar 26, 2009
How to stop music from playing music while surround sound is on the tv
First make sure the cables around the television and the surround sound system are not damaged. Then make sure the any grounding on the external sheathing of the cable is making good contact and that the braiding is not touching any other cable under the plug. You could try some better aftermarket connecting cables, and the ones that come with systems are used for price cheapness. Keep a space between cables and don't wrap them around each other. If none of that works, get some Ferrite Rings and thread three on each cable to the surround sound system, one at each end of the cable and one in the middle.
Cables with good braiding and gold flashed connectors as shown on this page are an indication of quality.
RCA Surround Sound Connections Analog 5 1 Audio Explained
Nov 06, 2016 | Audio Players & Recorders
How do i reset?????????
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 27, 2015 | RCA RT2781H 5.1 Home Theater System - 1000...
Rca rt2781h
install new window properly and the install the anti virus eset node 32...ur computer works nicely
Jun 17, 2014 | Audio Players & Recorders
My rca receiver cuts out after half hour rt2781h
Take some canned air and blow out the receiver, if it is in a confined space or had another device sitting on top of it, it could be over heating. Poor ventilation causes shutdowns and system failure
Mar 01, 2014 | RCA Audio Players & Recorders
Rca rt2781h loosing sound
Hi. replace the hdmi cable with a new one..
Aug 04, 2013 | Audio Players & Recorders
Check Speaker banner keeps coming on
If you have a ohm meter plug it into the back of the speaker it should read about 5.5 ohms
Nov 30, 2008 | RCA RT2500 System
Setting up the surround sound
Make sure the TV is 'looking' at the right input. If your system is connected to A/V input 1, then make sure the TV is set to that input. If everything is ok there, pressing MENU should bring it up. It's easiest if there is nothing in the DVD player.
You can also download the manual from RCA's site. CLick the link below to get it.
http://support.rca.com/main.html?pagetypeid=6&topicid=307&selectedmodel=RTD120&navtypeid=2&selectedFamily=video&prevPageIndex=2
Hope this helps, and please rate my advice, good OR bad.
Good luck!!
Feb 04, 2008 | RCA RTD120 System
Intermittent Sound from Home theatre system
confirm good wiring condition of celling speakers and disconnect it and connect it again-keep good ventilation around.
May 08, 2007 | Sony STR-DE598 Receiver
572 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
