Question about Frigidaire FEF336BC Electric Kitchen Range
My gas range has ncal in the screen - Frigidaire FEF336BC Electric Kitchen Range
My Kenmore 790 Electric Range has the code nCAL on the display. What does this mean?
This usually indicates an electronic oven control board failure. It could also indicate a failure of the sensor probe, one of the elements, or the wiring. Try turning off the power for a while, 10 minutes or longer. If the problem persists when power is reapplied and none of the keys respond, you need to unplug the range (or shut off the power at the circuit breaker). Then usually you need to replace the oven control board and overlay. If you post the full model number of your range, I may be able to check for the appropriate replacement part.
I hope this helps. Kenmore appliances with 790 were manufactured by Whirlpool.
Oct 25, 2016 | Kenmore Kitchen Ranges
The oven doesn't work
You have a control board issue, this model has a lot of problems with the control board.
Apr 12, 2014 | Whirlpool GS563LXSS - stainless Steel Gas...
Need replacement glass screen for BO696
I have one for sale, it was stored next to our range for a few years but never been used reply to make an offer plus shipping from (Tustin, CA.) brandogm@gmail.com
Jun 06, 2012 | Explorer Appliances BO696 Gas Kitchen...
On the screen, Red "LOC"
You range would seem to be in self clean mode. Simply switch that off and your range should work
May 03, 2011 | Kenmore Kitchen Ranges
F.O is stuck on screen and nothing works
local gas companies will sometimes offer to see what the problem is with gas appliances and outlets in your home. If this is a gas type, call your local gas company and have an agent come take a look.
Oct 08, 2010 | LG LRG30855ST Stainless Steel Gas Range
I AM GETTING A F7 CODE ON THE SCREEN
I AM GETTING A F7 CODE ON THE DISPLAY SCREEN ON MY GAS KENMORE RANGE. THE RANGE WAS INSTALLED A BRICK WALL NOT ABLE TO GET TO THE MODEL NUMBER UNLESS REMOVED BY AN PROFESSIONAL.
Jun 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas range shut off with PF on screen what does
The PF means there was a power failure, you should be able to clear this code by pressing the cancel button
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
GE Spectra XL44 Oven over-heating???
I got an e mail saying that there was a solution - have you seen it?
Nov 04, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FEF336BC Electric Kitchen Range Logo
52 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
