Question about Moen 7560C Extensa Kitchen Faucet
Handle sticking and hard to move - Moen 7560C Extensa Kitchen Faucet
  • 297 Answers
Hi Robert. Sounds like there might be some trash in your cartridge. Replace the cartridge, this should solve your problem.
Posted on Oct 21, 2013
Toilet handle sticks
It sounds like the nylon nut which holds the handle in place is too tight. Try loosening that nylon nut just a little to see if the handle moves easier. Sometimes if they are over-tightened, the handle will be stiff and hard to operate.
Apr 10, 2014 | Home
Sticking of KWC Suprimo faucet
My bathroom faucet handle (not same brand as yours) was so hard to turn that it pulled the base around with it on the vanity when I jerked it. I used an Allen wrench to take out one of the set screws holding the handle on, put the tiny straw of a WD40 can in the set screw hole, squirted WD40 inside the handle, replaced the setscrew, and worked the handle to and fro a few times to lubricate the inside. No more sticking!
Feb 22, 2014 | KWC 10.271.333.700 Suprimo Kitchen Faucets
2007 jeep liberty stuck in 4wl, handle moves down but still in 4wl drive
how'd it get there?
driving on hard pavement will in fact get it stuck,
are you on ice or dirt. ?
if on pavement, it will stick on all part time 4wd cars.
its not AWD, so can not be driven on hard pavement.
only ice,snow, dirt.
if on hard pavement move to the dirt side of road and it will now release. this is called windup, and will damage the drive line.
if you keep doing this.
Jan 21, 2014 | 2002 Jeep Grand Cherokee
Chevrolet cavalier door latch
tyr to workit by hand after spraying it with wd 40..that may free it up..they normally stick due to no lubricant.
Dec 23, 2013 | Cars & Trucks
My throttle is very hard to twist and doesn`t return back. I`ve used lube on it and the spring looks good. This is just a switch no cable so whats making it so hard to twist, cheap construction? Would...
SOUNDS LIKE TWIST GRIP ON HANDLE BAR IS STICKING REMOVE IT CLEAN INSIDE IT WITH WD40 IF THIS DOES NOT CURE IT STICKING YOUMAY NEEDTO REPLACE IT GOOD LUCK
Aug 12, 2011 | Tomos Sprint Motorcycles
I changed my oil last night with my boy friend who does frequent oil changes. Afterwords, my transmission started shifting extremely hard and late. Please help. I do not believe he drained the tranny...
e: subaru legacy transmission dipstick Transmission dip stick is behind the engine in front of driver side firewall. Move a few hoses out of the way, look down and you'll see it has a yellow top.
Other side (passenger) lower down yet, again move a few hoses aside, yellow top handle, you'll find the shorter differential dip stick.
In either case, if your gaze reaches the ground, you've gone too far.
May 21, 2011 | 2000 Subaru Legacy
My saw wont bevel cut easily...It will go to one side just fine....but the other side sticks and its really hard to move...I tried using some wd 40 and it helped a little but its still hard to do.
OK you are on the right track, I would remove the handle assembly on the back and push the travel as far back as possible to look at the bolt for stripped threads. then what I would do is use some dry lubricant and spray the washer and the housing and let dry, after drying reassembly tightening the nut enough to hold in place and reposition the handle. then try again, it could also be messes up in the circular area but for that I would recommend taking to a repair center.
Jan 23, 2011 | Makita 10" Dual Bevel Sliding Compound...
2001 frontier tailgate won't open
Remove the inner pannel. Then move the handle the connecting rod from the handle to the lock will move.Then pull or push the connecting rod helping the handle. When you get it open move the handle again if it moves freely then most likely the catch needs adjusting to adjust loosen the screws aroung the catch on the rear pannel move the catch out a little try closing the tailgate if it takes undue force to close then repeat moving the catch out until it is easy to shut simple rule is if it is hard to close then it will be hard to open! Leave the inner pannel off until you can easily open the tailgate with the handle as you may have to give the handle a helping hand to open until you have finished adjusting.
Aug 05, 2009 | 2001 Nissan Frontier Crew Cab
Gear stick stuck in neutral
You will have to take the top of the handle off to replace the button spring.
Apr 18, 2009 | 1993 Dodge Intrepid
1992 Chevrolet Lumina Euro car door door hard to open
the rod from door handle to latch is out of adjustment
Sep 29, 2008 | 1992 Chevrolet Lumina
Moen 7560C Extensa Kitchen Faucet Logo
165 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
