Question about GE WJSR1070A Top Load Washer
GE Washer overflows
The washer fills ups initially fine and empties....but overflows when it fills up on the rinse cycle.
  • 1 more comment
  • Ickster01 Sep 27, 2007
    Turned out not only was the hose plugged, but I had to use a coat hanger to unblock the inlet to the hose from the basket. Thanks
  • Anonymous Mar 15, 2014
    my washer doesn't stop filling up and overflows on the floor
  • Anonymous Mar 25, 2014
    IN COMING WATER SUPPLY IS FINE
  • 209 Answers
Washing machines of any make or shape have a level sensor, this normally consists of a thin pipe from the lower end of the machine (where there is water) normally enters the bottom of the outer drum casing, this thin rubber or thin plastic pipe goes up to the top of the machine just inside the casing, it leads into a "pressure switch" a circular disc object about 50 cms in diameter on average, also this has about 4 to 6 wires on it, this thin pipe becomes blocked not allowing air to be forced up the tube into the switch, not switching the machine water flow off when it gets to the correct level empty the machine, drain off the water, unplug the power supply, and clear out this pipe, normally its congealed old soap powder, place pipe back as it was, checking for any leak holes in it, if damaged, replace it with new, run machine again to test long winded but i hope i have explained it thoroughly
Posted on Sep 27, 2007
My washer initial had a rinse cycle problem where no rinsing occur after washing, now it spreads to the wash cycle where it is pausing at the this cycle, need urgent advice
The problem is you are not getting cold water fill. (rinse is all cold water fill) Check to see if the inlet screen is plugged by turning valve off that supplies cold to the hose attached to the machine, then removing the hose at the machine and checking the filter inside the water valve where the hose was just removed from. If screen is not blocked, replace water valve.
Nov 20, 2011 | GE Washing Machines
Top loading GE color profile washer (wpse4200a) won't fill
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Sep 19, 2009 | Washing Machines
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Washing machine overflows
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | GE WJSR1070A Top Load Washer
GE WJSR1070A Top Load Washer Logo
366 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
