Question about Dual Electronics CECT P168 Cellular Phone
Can not access all applications for i9 phone
I only have access to the first page of applications for my phone. I tried to get screen to 2nd set of applications with no sucess.
Please help!!!
  • 193 Answers
At the bottom of the screen below the alarm and service icons you will have 3 dots
the full white dot shows waht page your on, the far left do is fully white you are on page one the nmiddle page 2, the third page three. Using your stylus put firm pressure on the far right dot and drag to the left. it takes alot of pressure. continue this to get to the third screen,
For full help topics I have a cd available fo 10 us dollars. Has 100 of mp3 ringtones wallpapers, and java games. Guarenteed help on every question ever asked on these phones. If interested contact prestorse@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope.
Posted on Apr 23, 2009
How do i get the i9 to let me access my e-mail?
The Motorola i9 does not have a built-in email manager, so to access your email, you will use the i9's web browser to visit your email providers webmail page. Once logged on to your email providers webmail page, you will be able to read and post email through your Motorola i9 cell phone.
I hope that helps.
_______________________________________
Download Motorola i9 Manual Here.
Apr 21, 2010 | Dual Electronics CECT P168 Cellular Phone
No internet for i9
Hi,it seems you can"t access the internet from your i9,the best solution is to contact your service provider(orange) to give you the internet settings for your i9,because this settings varies with different phone depending on your service provider.have a nice day.
Take care
Mar 09, 2010 | Dual Electronics CECT P168 Cellular Phone
I WANT TO ACCESS MY INTERNET CONNECTION OF MY 8g I68+ TOUCH SCREEN I9
you just need to configure the settings manually.
Find settings here:
http://www.tradebit.com/filedetail.php/8624007
Nov 06, 2009 | Dual Electronics CECT P168 Cellular Phone
AT&T internet with the Sciphone I9 3G
Okay, I have solved my own problem. For information on setting up the internet for the Sciphone I9 3G go to http://gr8er1.com/shop/page/2?shop_param= They have tutorials on alot for these phones. Check it out for setting up your internet settings for the I9 3G. I would also recommend having an internet plan as this can get expensive if you do not have one. Good luck.
Sep 23, 2009 | Cell Phones
Annoying clicking sound with my new cect i9 3g
turn off the lock feature for the screen settings/security setup/autolock keypad. seems to have worked for mine but bummer not being able to lock keypad.
Jul 27, 2009 | Dual Electronics CECT P168 Cellular Phone
Can not connect using usb cable from computer to i9
I think i may have had a similar problem getting error around the lines of "Unable to access application data". What worked for me was, restarting my computer and opening the IDEN loader program on my computer first, then i plugged the cable into my phone this seemed to stop the error. i also had to make sure the USB connection was set to Application Access
Mar 23, 2009 | Motorola Cell Phones
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect phone - no calendar
the problem you have is there is no java on this phone and also it is a none supported phone /your money would have been better spent on the i9 cect it has java and calender
Jan 15, 2009 | Dual Electronics CECT P168 Cellular Phone
How can I download music and videos on my i9 phone
To fix this problem go to your menu go to settings than go to connections, now go to the USB hit OK now you will see memory card access, data modem, application access, GPS NMEA and finally help. Make sure it is on memory card access and not any of the other ones the memory card access is to allow a PC to use your phone as a memory card reader. The data modem allows a PC to use your phone as a modem. Application access allows certain PC applications to access the phone. and finally the GPS NMEA allows the phone to output GPS signal from EMU port.
Nov 15, 2008 | Cell Phones
Dual Electronics CECT P168 Cellular Phone Logo
405 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
