Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Machine does not turn on - Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
How to fixed a error code E43 of washing machine Siemens
This is related to the motor, and may be that the motor needs new brushes the Tacho (feedback mechanism) is broken, wiring or the motor control board. Most likely for a 6-7 year old washing machine is the brushes.
However, after changing them, you still need to reset the machine
  1. Turn off the machine (dial to 0)
  2. Open the door
  3. Turn on the machine on first program
  4. Close the door
  5. Turn off the machine
  6. Turn on the machine on the "six-o-clock" program, which is centrifuge
  7. Press the "option down" button and keep it pressed (This is the button left of the display)
  8. Turn the dial to "seven-o-clock" (empty/pump out program)
  9. Release the "option down" button
  10. Turn of the machine
This should reset the machine, and if everything is allright, it should work. If it does not work after changing the brushes and resetting it, something else is wrong, most likely the motor control board, or if the motor.
Oct 08, 2016 | Siemens Washing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
ASCO Washing Machine - AEA 12001
This is normal on most machine. Once the machine finished washing or you switch off the maching manally, you will have to wait for around 2 to 3 mins for the mechanisim to unlock the door.
Apr 07, 2014 | Asko Washing Machines
Turning this machine off?
The ON button (on your control panel) turns the machine on or off. When the machine is "off" a minimal amount of power is still supplied to the machine. It's like in "sleep" or stand-by mode. To completely turn it off ... i.e. disconnect the power supply to the machine, you'll have to (after turning it off), unplug the power cord from the back (bottom left) of the machine.
Mar 05, 2014 | HP PSC 1610 All-In-One InkJet Printer
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Mar 01, 2014 | Singer Co Singer Talent 3321 Sewing...
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
Unable to use upper feeder on CopyCentre C20
Turn the machine off. Disconnect the white cable on the back of the machine. Turn the machine back on let it come to ready.
Turn the machine back off, plug the feeder back on and turn the machine back on.
The machine seems to forget it has the feeder from time to time.
It has to boot up with it unplugged to reset.
Nov 09, 2010 | Xerox CopyCentre C20 Black and White...
Can the HP 1040 fax be cleaned to remove the two vertical lines that print? How? There is no glass to be cleaned and it does seem that the machine can easily taken apart?
This seems to a hardware problem. Resetting the machine fixes it most of the time.
There are many levels in reset, please try the the next level if the 1st did not fix.
Power Drain:
* Turn OFF the machine, disconnect the power cable from backside of the machine and from wall outlet.
* Press and hold the Power button for 60 seconds.
* Connect the cable and turn ON the machine.
Partial Reset
* Remove the power cable from back side of the machine while its ON.
* Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
* If machine turns OFF, press power button to turn it ON.
Semi-Full reset
* Remove the ink cartridges.
* Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
* Insert the ink cartridges.
NVM Reset
* Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Riztech
Sep 25, 2010 | HP 1040 Plain Paper Inkjet Fax
Toner just replaced; asking to "reset" Broken Registration.
Turn machine off. Hold * and 1 and 3 down at the same time while turning machine on. This should reset "Broken Registration".
Sep 22, 2009 | Xerox Office Equipment & Supplies
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
21 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
